Question about Vehicle Parts & Accessories
Remote start only works when I'm close to the vehicle
    Sergeant:
  • 206 Answers
Hi
change your car remote batteries and see if it works better
Remote start only works when I'm close to the vehi - 25640862-extj4arg1t42xbh3l3byl5v2-3-0.jpg cheers
Posted on May 29, 2015
Remote start only works when next to vehicle
Hi, i would guess ur remote batteries are needing replaced. Otherwise chk the ant. That is added on ur windsgield. It may have a connection issue.
Jan 30, 2014 | 4103LX Remote Start System with Two...
Engine wont shut off after vehicle started with remote starter
Tools: 10mm torque wrench
Step 1: Find the release bonnet lever or button in the car.
Step 2: once the bonnet is open, locate the battery pack.
Step 3: Then locate the negative charge and unplug the connector to the terminal by using your torque wrench.
Step 4: Then replug it in and close Start the car up and it should work.
Hopefully it works.
Jan 18, 2014 | DEI Python 1400XP Remote Start/Keyless...
How to check the remote if it is functioning or not
most remotes only open / close the door locks. The key has to be in close proximity to the engine immobiliser to work. Once you are in the car just put the key in the ignition and see if it works.
Jun 06, 2013 | Air Conditioning and Heat for Mahindra...
Will not unlock doors. Battery is good and flashes all lights on transmitter and LED inside vehicle. Remote start will start up and shut down vehicle fine. Just does not lock or unlock doors. Locks work...
Have you changed the battery recently? My remote has a bad habot of slightly misaligning the cel switches if I don't close it exactly right. For my Chrysler van the sliding door switch is affected that way. All else works, though. I end up opening the remote again and ensuring it snaps shut all the way around with just one compression. If an edge doesn't close it's try again. The good news is it's virtually always the remote at issue and nothing expensive in the vehicle.
Jun 06, 2017 | 7900 RB 7900 2Way Color LCD Remote Start...
What does hood pin is active mean? My vehicle's lights flash 6 times and will not remote start.
Do you have the hood open? If you have the hood open then car won't remote start. It is a safety feature so the car does not start while someone is working in the engine compartment. If the hood is closed then open the hood find the hood pin and disconnect then try to remote start the vehicle again. Could have a faulty hood pin.
Jan 07, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Have had a Dei valet 561r remote on my Honda van for several years. Worked flawlessly. Recently, it began working intermittantly. Did not work for several days. Then worked for about a week. Then nothing....
sounds like your car battery was also replace or it die
believe it or not the remote start needs to be reprogram again
find the valet switch, this what you are going to do
make sure ac radio and any other accesorie are off
start the car with the key within 2 seconds or less press and hold the valet swith, and way until the
led turns on and the parking lights on the vehicle flash about 12 seconds
no turn off the car close the door and start the vehicle with the remote good luck
Nov 19, 2010 | Directed Dei Valet 561r Remote...
Mts mode for preset manual trans auto start function enable,does not allow car to start, instead the park light blinks seven times and give an error tone ... Thank you
There is a sequence necessary to set the Viper every time you exit the vehicle: park the vehicle, put in neutral, place foot on brake, set parking brake,remove foot from brake, remote start vehicle with remote, remove key (vehicle should remain running), exit vehicle and close door, arm the alarm with remote (vehicle should shut down). The system is now set for MTS remote start. Test the system by remote starting the vehicle now (it should remote start at this point). If you open any door after the MTS remote start has been set, you will have to do the programming sequence again.This is a safety feature because something may have changed, i.e. parking brake released when the door was opened. You have to do this sequence each time you park the vehicle if you intend to use the remote start feature.
If this does not work, there may be an issue with the installation, i.e., the door trigger connection. Using dome supervision as a door trigger won't work because during the arming portion of the above mention programming sequence(when the vehicle shuts down), the interior lights will illuminate and the Viper will read it as a door opening. So, actual door trigger wires must be used.
Oct 23, 2010 | 5900 SST 2-Way Security System / Remote...
Cannot get to work with manual transmission please help with any ideas?
There are several steps necessary for the unit to function with manual transmission. Now,the unit comes programmed for manual transmission out of the box. Next, the neutral safety wire (thin black with white stripe) MUST be connected to the parking brake wire. Also, the tachometer wire MUST be connected. Check the neutral safety switch as well. Did you install a clutch bypass? All that is left is the system setup for remote start: Start the vehicle with the key,make sure all doors are closed, put the vehicle in neutral, press on the brake, apply parking brake, release brake, within 15 seconds remote start the vehicle, the parking lights will flash to confirm the remote start activation, turn the ignition off ( the vehicle should stay running.Exit the vehicle. Arm the alarm ( the vehicle should shut off). You are now able to operate the remote start. This process must be done each time you exit for the remote starter to function on a manual transmission vehicle. Don't worry ,you'll get used to it.
Oct 12, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
What to do if remote does not start the truck?
If the remote starter it was working before, check that all the doors trunk and hood are closed. And remote start the vehicle, approach to the window to see if the dash board lights turn it on if it does; check the pin switch make sure when you close the hood the switch get closed too if this is Ok. Check the tack wire you?ll see it is coming out of one of the ignition coils.
Jan 06, 2010 | Omega MARS-22 Remote Vehicle Starter with...
2007 Saturn Aura; when trying remote start horn beeps three times but doesn't start. I've replaced battery. Other functions work fine - door locks, trunk opens, alarm arms. Other key fob works fine.
press the lock button on the remote then press the remote start button. if this does not work check remote start status using steering wheel buttons
Jan 03, 2010 | 2007 Saturn Aura XR Sedan
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
