Question about Toys
How do I attach the pieces to each other? - Toys
    Top Expert:
  • Toys Master
  • 44,260 Answers
Gorilla glue
Posted on May 14, 2015
A chrome piece (1 of 4) on the front grille broke off on my 2005 Kia Sportage. I need to remove the grille to get access to the screws that attach the chrome piece.
Hi there my name is Brandon I am a mechanical n electronic engineering technician I am the man reg mechanics call when they cant fix something it may have a spring you may have to push both side in to get it out some are a pain
Feb 02, 2016 | 2005 Kia Sportage 2.0
I just bought an led light set for my new diamondback bike. Which is fine except I don't know how to attach it to the bike the pieces that came with it only attach together. Am I missing something?
If you feel pieces are missing, return the unit and get a new one. Aside from that, you would have to improvise a fastener to attach to the frame or handlebars. 7_16_2013_10_17_55_pm.jpg
Jul 15, 2013 | Cycling
1992 toyota camry rear assemmbly
Are you wondering what the piece is called?
Mar 29, 2013 | Vehicle Parts & Accessories
How do you change from tool attachments to floor?
On the front of the recovery tank is a slide-out piece. lift up and out (or down-depending on your model). On the end of the hose is a piece the same size and shape as the one on the tank. Slide it down in the slot in the recovery tank. You'll see a little push door labeled
"upholstery and floor attachment". Push down on the top of the door to open it. Then take the hose attached to the piece inserted in the recovery tank and push it into the upholstery and floor access door.
May 15, 2012 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Will not spray
There are a handful of places that the mechanism can get blocked. The easiest test is to remove the brush attachment and pull the trigger. If it sprays fine, then the blockage is in the small length of tubing in the brush attachment. The most likely place is in the small plastic piece at the very end of the attachment. You should be able to see the small plastic piece where the tubing ends, this is a common place for a blockage. You can usually use a piece of thin wire to clear the blockage.
Nov 28, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Won't spray, only dribbles
There are a handful of places that the mechanism can get blocked. The easiest test is to remove the brush attachment and pull the trigger. If it sprays fine, then the blockage is in the small length of tubing in the brush attachment. The most likely place is in the small plastic piece at the very end of the attachment. You should be able to see a small plastic piece where the tubing ends, this is a common place for a blockage. You can usually use a piece of thin wire to clear the blockage.
Nov 12, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Lost piece to charger that plugs into wall
Go to this sight .http://www.ylmart.com/kodak-easyshare-z730-charger.html
Mar 20, 2009 | Kodak EasyShare Z730 Digital Camera
Plastic piece came loose inside printer
The parking mechanism front spring has a tendency to come off in the C4x family of printers. Re-attaching it is a fiddly task not covered in the service manual. The pictures show: a general shot of the parking mechanism from the front; a shot of the actuation lever, illustrating where the front spring attaches to it; a view into the empty parking mechanism compartment showing where the lug is to which the bottom end of the front sprint attaches; a suggested tool for re-attaching the front spring, made from a large paper clip.
Proceed as follows, using a torch where necessary: lift the parking mechanism out its holder; be careful not to detach the drain pipe. Using the tool, attach one end of50f32be.gif54a9806.gif88c5669.gif9145528.gif the spring to the lug at the bottom of the parking mechanism compartment. Remove the tool and leave the spring laying at the bottom with one end attached to the lug. Replace the parking mechanism in its holder, with the actuation lever in place. Now for the fiddly bit! Peer into the compartment to locate the free end of the spring and get the tool on it. Pull the spring until you can put the free end over the lug on the actuation lever. Remove the tool.
Sep 15, 2008 | Epson Stylus C42UX InkJet Printer
Toys Logo
77 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
