Question about HP PhotoSmart Office Equipment & Supplies
I need to know what ink cartridge to use for my Hp photosmart 355 printer
I found out that it is discontinued but I have one that still works but I don't know what ink cartridge to but. I got the 110 but it is not the right one.
  • rdjagger Apr 11, 2015
    U sure that model number is correct?
    Top Expert:
  • HP Master
  • 74,239 Answers
Posted on Apr 11, 2015
New black very faint
1. hope you have not touched the contacts or head those protected by pink tape.
2. or the ink is dried up
Replacing Cartridge HP Photosmart C4280 All in One Printer
Apr 06, 2016 | HP Photosmart C4280 Aio Printer
What color and black and white cartridges should I use for a HP Photosmart 1115 printer?
It looks like your Photosmart 1115 printer uses an HP45 black ink cartridge and an HP78 tri-color cartridge. Some HP printers will accept re-manufactured ink carts, while other HP printers will not...just so you know. I've always bought genuine HP ink cartridges on eBay to save $$$.
Jun 23, 2014 | HP Photosmart 2610 All-In-One InkJet...
Ink threshold exceeded
Sad to say I know how to fix this.
1. Power up the printer
2. set printer's date to the current day.
3. On the keypad press the * and # keys together
Now press one at a time 1,2,3 for the code
"screen stould display a white backround with 2 lines of info"
4. remove all the print cartridges
5. Press the >> arrow button twice until "reset menu" is found
6. Press OK
7. Select Partially full reset Press ok
( the printer will take almost to minutes before it powers down)
8. Power up the printer and follow the steps.
reinstall ink ect......
I don't know why this happens but I sure a lot of printers are in the trash because of this. If you print out a SELF TEST REPORT the
dates on the age of the ink Cartridges are likely out of life range.
Planned obsolescence by HP can be found all over the web. This could be one of those.
HP Photosmart 3000 C6100 C7200 PSC 7280 Printers HP 02 Cartridge...
Press the helpfull Thanks!!!!
Feb 04, 2014 | PrintCountry HP Photosmart C6280 Inkjet...
On HP Photosmart 7960, which cartridge to replace when the blue and green look pale
The printer takes a tri-color cartridge and a black cartridge. So anytime there is an issue with color, replace the tri-color cartridge. As far as using compatible inks, you will not be able to use HP's software for ink levels with compatible inks. This feature will work only with HP ink cartridges.
Oct 23, 2011 | HP PhotoSmart 7350 InkJet Printer
To know when ink needs rep
With compatible ink you will just have to watch for colors fading. HP software supports only HP ink, so the ink monitoring software will not function with compatible cartridges
Oct 21, 2011 | HP PhotoSmart 7960 InkJet Printer
My hp photosmart all in one printer c4480 keeps saying incompatible print cartridge when its the right cartridge and its full of ink and reseting it isnt working. it was working before and now it just...
Hy. I have found a different solution for c4480 "incopatible cartrige". it worked for me so i hope it works for you to
Steps:
1. Press X+power at the same time
2. Press BLUE, GREEN, GRAY
3. press BLUE until you see "INFORMATION MENU"
4. press OK
5. Press Blue until you see "CHECKSUM FOR RELOCK DATA INPUT"
6. OK
7. Press X until you exit all menius
8. When promted for aliement cancel it with X.
It should bypass the error
Dec 14, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Keep getting this message incompatible ink cartridge on my hp photosmart c4480 all in one printer, helppppp
Hp knows about your issues you can read the forum here, Currently there working on a critical update.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Incompatible-Cartridges-after-Critical-Update-HP-Photosmart/td-p/107505
Let me know ether way we are here to help. Please do not forget to leave a rating before you go, thanks
Aug 10, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
Want to know where u put the photosmart ink in printer
Open the print cartridge door. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again. IMPORTANT: The device must be turned on to insert cartridges.
You can see the location and proceedure to change the ink cartridges on page 14 of the manual (found here: http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf). Sometimes a picture is worth a thousand words <grin>.
Hope this helps,
Chris
Mar 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Seeker5211
Seeker5211
