Question about Dryers
Lint filter not going down all the way - Dryers
  • 2,992 Answers
Reshape the screen so it will fit. Plus it may need cleaning around all edges of both the screen and the screen inlet.
Posted on Apr 11, 2015
Maytag drier lint screen will not go in all the way
Take lint screen out, look into slot and remove the sock that's blocking it....
Oct 12, 2014 | Maytag MED8000AW Maxima XL HE Steam Dryer...
My kenmore elite dryer that i bought 2 years ago lint trap corner is catching my clothes and tearing them. we had it replaced and its doing it again. I am tired of messing with it. Please help.
don't know if you already had this fixed,usually this is caused by not having your dryer cleaned out,the lint builds up inside the duct that the lint filter slides down into and has to be removed and cleaned out.also in some of the kenmore dryer ducts there's a metal clip inside the duct that can come loose and hold the lint filter up.these are the two most likely causes for this to happen.
Sep 23, 2013 | Kenmore Elite HE4 Electric Dryer
Lint screen won't go down all teh way.
take the metal duct out that the lint filter slides down into,stick the metal strip through the hole in the side of the duct so that when it's in the bottom part of strip is flush up against the back side wall of duct and it should have like a half inch or so sticking out of the hole,but before you stick it in clean out the duct and with a thin long screw driver open the plastic cover that the filter slides through and poke out any lint in the slots that the filter slides in.so unplug the dryer,remove the bottom panel of dryer,remove the lint filter and screws that hold the lint filter duct in place they are 1/4 inch head screws,clean out the duct and the side slots up above the duct in the plastic area then slide the metal strip into the hole so that the bottom part that you first put into the hole fits flush up against the back inside wall of duct and the top of strip will be flush to the outside wall of duct and like around 1/2 inch or so still showing.hope this helps
Jun 02, 2013 | Kenmore Elite He5T Dryer Heating Element...
The lint filter does not fit properly in the lint trap. The corner of the filter catches an item of clothing and twists it. I have to check it several times to clear the item away. I assume this...
We have the same model and experience the same thing. The way I fix it is to remove the filter, then with a flash light I look down into the lint trap. You will notice that lint has built up in the track where the lint filter sits. I use a wooden skewer to run along the track and lift out the lent. Hope that helps
Aug 21, 2011 | Samsung DV448AEE Electric Dryer
I can't find the filter location for Hoover 202M 5.5kg washing machine. Can you pls help.
The filter is in the agitator. Remove the agitator cap, and you will find it down there. The filter is pretty much useless. Even though you might get some lint in the filter, if it wasn't there the lint would go down the drain. This machine has a neutral drain feature where the lint gets pumped out with the rinse water before the bowl turns, so preventing the lint from being stirred up nd put through the clothes. Cheerts Tony.
Sep 07, 2010 | Washing Machines
How do you reset the lint filter?
Hold down the filter button for 60 seconds until the beep is heard and the release and the lint filter should go off.
Mar 09, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Lint screen wont go back in
not sure what model you have, but the strap usually holds it from dropping to far down, remove filter use a flashlight to look down the filter housing, usually lint blocks the filter from going down properly. clean out that are witha vacuumm and try again, if your sure its the strao then bend it or buy a new stap however i have never seen that problem in 15 years of service. hope this helps.
Sep 17, 2009 | Whirlpool Washing Machines
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Hi, I have a Maytag gas Dryer, Legacy series, heavyduty. I clean the lint filter each time used but there is still a build up which I cannot get out unless I remove the filter housing. How do I do this?
you do not have to remove the lint housing all you have to do is go to an applaince store and ask for a lint brush you then take the lint brush and shove it down where the filter goes to loosen the lint turn on your dryer and it will blow it outside
Dec 26, 2008 | Dryers
Kenmore dryer
Take the filter out and remove those 2 phillips screws on the top.
Take the back off. Get the screws out the filter housing.Wiggle the housing over enough to remove the object.
Jul 30, 2008 | Kenmore 62802 Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
