Question about LG LMVH1750ST Over-the-Range Convection Microwave Oven, Stainless Stee1.7 cu.ft. Oven Capacity, 950 Watts Microwave/1500 Watts Convection, Sensor Cook Technology, Convection Bake, Convection Roast, Combination Speed Cook, FuStainless Steel Interior, Hal
How do I change the internal lightbulb? - LG LMVH1750ST Over-the-Range Convection Microwave Oven, Stainless Stee1.7 cu.ft. Oven Capacity, 950 Watts Microwave/1500 Watts Convection, Sensor Cook Technology, Convection Bake, Convection Roast, Combination Speed Cook, FuStainless Steel Interior, Hal
  • LG Master
  • 2,963 Answers
Your owner's manual should show how. No manual, try manualslib.com
My old sears microwave light bulb is in the upper front left hand with bulb top up and socket down but behind a screen. There are screws to remove the upper fan apparatus, which appears to make the side available to extract the bulb. Probably a very special bulb, so I would get one before going to that trouble. It might also be the switch that is bad rather than the bulb. That probably requires removing the outer surrounding cover.
Posted on Apr 11, 2015
I have an older JENNIE cooktop model VVV that is getting no power???
check fusebox for tripped breaker..if its gas look for tripped gfi outlet..some have internal fuses also..
Feb 02, 2014 | Cooktops
Recently i have purchased Prestige induction stove, can you describe what does E3 mean?
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
Jul 16, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
How to un lock my GE Profile Induction cook top?
Try turning off the breaker for at least 10 min and re apply power. If this doesn't work, then there's an internal problem.
If after 10 minutes the cooktop is STILL locked:
Push the touch pad that looks like a padlock for at least 5 seconds. The lock light should go out.
Nov 15, 2010 | GE Profile JP930 Electric Cooktop
Cook top is obsolete. burner on right side turns on but heats up slowly
that happens when the controll knob rheostat becomes weak and break down internally you just need to replace the controll switch
Jan 19, 2010 | Jenn-Air JED8430 Electric Cooktop
GE jp938 just quite. No response to any of the
ck the internal wiring under the top / it may have burned a wire end . make shure you have power on both lines ( 220 v ) m m
Nov 20, 2009 | GE 30 in. Profile JP938 Electric Cooktop
Oven bulb broke while I was cleaning oven.
This should be pretty easy. Please unplug the oven, or turn it off at the fuse/breaker panel first! Then use a pair of small pliers to grab the center of the remains of the lightbulb and spin it out. If you can't get hold of anything in the center of the bulb, you may have to use a screwdriver to bend the edges of the metal shell away from the socket, just enough that you can grab the edge of it with the pliers to turn it out.
Hope this helps, please rate :)
Mar 28, 2009 | Brown Stove Works 23 in. EL03 Electric...
The lock on my thermadore hybrid induction cooktop
try turning off the breaker for at least 5 min and re apply power. If this doesn't work, then there's an internal problem.
Mar 18, 2009 | Cooktops
Cooktop WIring
To complying with changed Codes (effective in 2002 ) regarding stoves, ovens and dryers. You will need a 120/240 volt 4 wire 40 amp and 50 amp circuit. This
Decades ago it was permitted to use a 3 wire system (having two 120 volt hots (Black and Red) and 1 combination ground/neutral wire) (green and white) to serve stoves, cooktops, ovens and dryers.
The Code change now requires all stoves and dryers in NEW construction to have the 4 wire set-up (now having two 120 volt hots, 1 white neutral and one green or bare wire ground).
Existing wiring is grand-fathered under the Code change.....I advise you to change the feed wiring over to the the 4 wire set-up...
because - as with ALL Code changes in the past...it will eventually become mandatory for all stoves, ovens and dryers as the grand-father clause drops off. By complying now...
BUT the wiring will need to change to 8/3 with ground. (having 4 wires inside one outer jacket).This is the primary reason for the Code change....to provide a greater margin of safety to the user.
I can NOT recommend the 3 wire hook-up...the 4 wire provides a seperate ground and neutral -
which makes the chance of a user shock when touching the metal frame (from an internal fault in the oven) much less likely then the old 3 wire set-up....
which did NOT have the seperate ground and neutral.
Krazytech
Apr 05, 2008 | Whirlpool 30 in.GJC3055 Electric Cooktop
Stove burner/ maytag double oven
did you use ajax or any cleanser that might leave a powdery residue is any of the air/gas holes clogged is the burner clogged internally, can you put anotheer burner in that place to see if it is the burner check it out.
Dec 28, 2007 | Cooktops
Stuck auto ignition
Either one of the ignition switches are stuck down internally or the ignition pack is faulty, no other possible cause. Regards Advisor
Aug 29, 2007 | Smeg 23 in. SE64 Gas Cooktop
LG LMVH1750ST Over-the-Range Convection Microwave Oven, Stainless Stee1.7 cu.ft. Oven Capacity, 950 Watts Microwave/1500 Watts Convection, Sensor Cook Technology, Convection Bake, Convection Roast, Combination Speed Cook, FuStainless Steel Interior, Hal Logo
132 people viewed this question
Top LG Cooktops Experts
cwradio73
Dan Apthorp
ray gallant
Are you a LG Cooktop Expert? Answer questions, earn points and help others
