Question about Bernina Sewing Machines
I have a Bernina 1630 Inspiration Plus and it worked perfectly well. Then, it doesn't want to select any stitches other than straight stitch
  • Bernina Master
  • 1,860 Answers
Could be a problem with the computer or a gear, having it checked would be a good idea
Posted on Jun 03, 2015
  • 23 Answers
This problem can originate from the stepping motor or main board. If you need to find these parts we do supply them. Visit www.sewingmachine.com.au to find more information about the part or inquire about it.
Posted on Dec 29, 2015
  • Bernina Master
  • 10,205 Answers
Sorry I am unable to offer advice for your 1630, however, you may consider joining Yahoo's Group BerninaThirtySomethings:
http://groups.yahoo.com/neo/groups/BerninaThirtySomethings/info
It is quite an active group and several members are Bernina gurus who offer troubleshooting advice to owners of Bernina older models such as yours.
Posted on Jun 05, 2015
  • 21 Answers
SOURCE: Bernina 1630 problem
Your feed dogs sound like they are getting stuck,chec whether they are on the down position,and also make sure that you have cleaned any lint that builds up in the bobbin area, if all fails it will have to go into the technician,
Posted on Sep 21, 2008
  • 26 Answers
SOURCE: stitch selection does not work
The switch could be bad or the mechanics that physically move the needle for the zig zag could be broken/worn. Hope you get it fixed soon!
Posted on Apr 04, 2012
SOURCE: can't find straight stitch setting on singer inspiration model 4228
do you have a manual? if not
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 4228) & click search
Posted on Apr 24, 2012
  • 1564 Answers
SOURCE: bernina 1630 skips stitches off and on when doing straight stitches and zig zag
Check that your needle is inserted correctly.
Posted on Sep 10, 2012
  • 2963 Answers
SOURCE: I have a Bernina 1630 Inspiration Plus and it worked perfectly well. Then, it doesn't want to select any stitches other than straight stitch?
Owner's manual troubleshooting. No manual, try manualslib.com
It's probably like a computer. Time to "reboot" to get back to square one, if there is such an option. If not, I'd try to unplug overnight to see if it might reset.
Posted on Apr 11, 2015
Testimonial: "Thank you for your reply. The problem is fixed. My 1630 is purrrrfect - purrrring like a kitty!"
I cannot get the green decorative stitches to work. I'm insure if my Bernina 930 is broken or I'm just unfamiliar with this machine. How do I set my machine for the embroidery stitches?
There are 2 levers on the top that need to be set. One shows the green stitch selections. That needs to be set to your stitch choice. To its right, there is another lever called the "changeover lever." It needs to be pushed all the toward the back of the machine--that switches it from straight stitch to decorative stitch.
Then on the bottom front on the right is a large knob. Both the outer ring of the knob and the inner knob perform different functions. One drops the feed dogs for darning or raises to activate the feed dogs to pull the fabric through the machine. The other part switches between the red and green stitch selections. When that knob is turned the light should show green or red to coordinate with the stitch selection lever on the top of the machine.
So to make decorative stitches, there are 2 levers that need to be moved plus the red/green activator knob. In addition, you will want to adjust the stitch width dial and the stitch length lever to widen or lengthen the stitch.
If you need a manual for your machine, you can download it free here:
BERNINA Support Machine and Accessories Finders and Software Support...
Apr 07, 2016 | Bernina Sewing Machines
Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Jun 05, 2008 | Sewing Machines
Apr 11, 2015 | Bernina Sewing Machines
How do I change the needle position on my Bernina 1630?
Not sure, but if this is the one with the track ball, try pushing in on it to activate needle position.
Nov 18, 2014 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Bernina 1080 while sewing normal stitch, stitch
What stitch to you have selected for it to do? Please check to see if it is set for straight stitch only.
Linda at Relics
www.sewing-machine-manuals.com
Jul 05, 2011 | Bernina Sewing Machines
Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Feb 21, 2010 | Singer Inspiration 4206
Sep 01, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
203 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
