Question about Maytag Dryers
Filter not going down all the way - Maytag Dryers
  • Maytag Master
  • 2,760 Answers
Clogged lint traps or there holders are a big complaint on these , id look in there first with a flashlight for something big down in there , also be sure to disconnect all power to unit before fishing in there with anything especially wire , some models put the moisture sensor down in there , could present a shock hazard
Posted on Apr 21, 2015
    Top Expert:
  • Maytag Master
  • 43,059 Answers
Straighten out a wire coat hanger and go fishing see what you hook at the bottom
Posted on Apr 20, 2015
Maytag drier lint screen will not go in all the way
Take lint screen out, look into slot and remove the sock that's blocking it....
Oct 12, 2014 | Maytag MED8000AW Maxima XL HE Steam Dryer...
Remove filter timer message
On on the top of the projector click the down Menu arrow, then go down to advanced options, use the down arrow to highlight the filter time, then reset the filter time.
This will reset the counter to zero hours.
Mar 06, 2014 | Hitachi CP-X250 Multimedia Projector
My intex sand filter collar ring will not lock down
1st make sure filter basket is all the way down ,It only will fit all the way down 1 Way , this is a common problem with these, 2nd on new housings allways use a touch of foodgrade/ water proof grease on O-ring seal , this will make the seal pop right into its groove and seal up tight !! this grease is easy to find in your local hardware supply store look for Kitchen faucet grease , only use this type of grease Not petrolem jelly as this will chemically dammage the housing and ring
Jul 17, 2012 | INTEX Sand Filter Pump
I am unable to reset the filter timer because i lost the remote, can this be done without the remote.
Use the projector's menu to go into 'Advanced Menu Settings'. Go down to 'OPTIONS' sub-menu, go right then down to highlight the "Filter Time". Press and hold the arrow to the right for 3s to bring up a popup to reset the filter time; preset the up arrow to reset the filter time to 0h.
Sep 14, 2010 | 3M X45 Multimedia Projector
On my 2005 chevrolet cobalt 2.2L engine where dose the carbond fliter go
The carbon air filter (ACDelco filter 52493319) is located behind the glove box. To change your filter:
  1. Open the glove box
  2. Push in the stops (tabs) with rubber bumpers on either side of the glove box
  3. Lower the glove box down until stopped by the retractable string
  4. Slide the retainer for the string up and out of the whole (it's okay to let it retract back in the dash)
  5. Lower the glove box down the rest of the way
  6. Release the three tabs covering the filter door (you should see a Delphi sticker just below the tabs)
  7. Flip the door down
  8. Pull out the old filter (note the direction of the air flow is DOWN)
  9. Insert the new filter
  10. Reassemble
Sep 04, 2010 | 2005 Chevrolet Cobalt
Lint screen wont go back in
not sure what model you have, but the strap usually holds it from dropping to far down, remove filter use a flashlight to look down the filter housing, usually lint blocks the filter from going down properly. clean out that are witha vacuumm and try again, if your sure its the strao then bend it or buy a new stap however i have never seen that problem in 15 years of service. hope this helps.
Sep 17, 2009 | Whirlpool Washing Machines
The change filter light keeps coming on
In the manual, it says you have to go in the menu to the OPTION submenu. Go down to FILTER TIME and hold the right arrow down for 3 seconds. It will then go into a mini-submenu that, when you press the up arrow, will reset the filter time to 0. The key is to hold down the right arrow initially for THREE+ SECONDS to get into the reset filter time menu. This is NOT the submenu that has RESET - EXECUTE. That is a different thing that doesn't reset filter & lamp time.
Here's the manual online:
http://www.hitachi-homeelectronics.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/01CP-S235-OG-ENG.pdf
Jan 05, 2009 | Hitachi CP-S235 Multimedia Projector
It says reset filter
Reset the filter timer. (1) Turn on the projector. While the projector running, press the MENU button to open the menu. (2) Choose the “OPTION” on the menu using the up/down button, then press the right button or ENTER button. (3) Choose the “FILTER TIME” using the up/down button, then press and hold the right button of projector or the RESET button of remote control for 3 seconds. (4) Choose the “RESET” using the up button.
Dec 04, 2008 | Office Equipment & Supplies
Hitachi cp-s235
Did you clean the air filter? You should vacuum it or use an air dusting can to clean it out.
Afterwards, reset the time in the menu. In the manual, it says you have to go in the menu to the OPTION submenu. Go down to FILTER TIME and hold the right arrow down for 3 seconds. It will then go into a mini-submenu that, when you press the up arrow, will reset the filter time to 0. The key is to hold down the right arrow initially for THREE+ SECONDS to get into the reset filter time menu. This is NOT the submenu that has RESET - EXECUTE. That is a different thing that doesn't reset filter & lamp time.
Oct 07, 2008 | Hitachi CP-S235 Multimedia Projector
Dryers Logo
66 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
