Question about Fuji FinePix S6500 Digital Camera
Attachments? no problem, just want to know if i can attach a telephoto lens to my finepix s6500? if so what do i need? thank you.
Re: attachments?
There are loads of lenses on ebay such as 58mm 0.45X Wide Lens FOR Fuji S6000 S6500 fd BKs.gif I think any will work provided they are 58mm
Posted on Dec 28, 2007
0 characters
3 Points
How to attach wide angle lens to telephoto
I don't understand your question...a wide angle and a telephoto are two different lenses.
Nov 12, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Finepix adapter ring AR-FX3 55mm for Fugi 3800 digital
The ar-fx3 screws on to the camera and any lens screws on to it.
Oct 07, 2009 | Fuji FinePix 3800 Digital Camera
I have a Fuji Finepix S5600 and would like to know if you can change the lenses on it or not. Just don't want to break it trying. Thanks
The S5600 uses a non interchangeable lens. It's a fixed lens camera.
You can how ever purchase filters or adapter rings etc to attach to the front of the lens.
Oct 04, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Help!!!i lost the software that came with my fuji fine pix S6500
here's the direct link for the S6500fd photoshop plugin download from adobe. photoshop should open raw after you've installed this:
Here's  the adobe downloads centre link in case you need to check up on everything & the installation instructions.
Cheers Andy.
Mar 25, 2009 | Fuji FinePix S6500 Digital Camera
I have an SP 510 UZ digital camera. I have just bought a new telephoto lense, but I can't seem to get the existing lense off the cammera. Help!
Hey john42hockey,
The lens on this camera is not removable. What you need to attach the telephoto lens to your camera is to get a 43-55mm Step-Up Ring, and a CLA-1 lens adapter tube. You should first attach the lens adapter tube to the camera, and then screw the step up ring into the tube and then screw the telephoto lens into step up ring. I have included a link to the manufacturer where you can purchase both the step up ring, and the lens adapter tube incase you need these. I hope this helps!
Go Ahead. Use Us.
Jun 20, 2008 | Digital Cameras
Adding a telephoto lens
Try zooming in. That usually gets rid of the "vignetting" you are experinecing.
May 02, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
S6500fd,s6500 lens types.
The lens is a 28-300mm zoom and is permanently affixed to the camera (s6500fd).
The only extras are listed here:
Dec 13, 2007 | Fuji FinePix S6500 Digital Camera
Fuji s6500 different lenses
any type of filter of anybrand, also any type/brand of teleconverters can be use with s6500 as long as it's 58mm
Telephoto lens for digital camera
It will not work because it is the wrong thread size. Here is info on the Olympus TCON-17 lens for the 5050: TCON-17 (1.7X) Telephoto Conversion Lens Extend the capabilities of your digital camera with the TCON-17 Telephoto Converter lens. This telephoto lens will increase the magnification of your subject by 1.7x when your camera lens is set to the telephoto position. This will help you bring in the subject when you can't get closer, for example, shooting sports or concerts. Please see below for additional items required to attach this lens to your camera. The following models require the CLA-1 and 43-55mm Step-Up Ring: C-2000/2020/2040/3000/3020/3030/3040/4000/4040/5050 Zoom ....... The video lens is too small (diameter). If you found one with a 43mm thread and put it on the 5050, you would experience severe vignetting (clipping of the corners of the photo).
Sep 05, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Fuji FinePix S6500 Digital Camera Logo
127 people viewed this question
Top Fuji Digital Cameras Experts
Richard Roberts
Are you a Fuji Digital Camera Expert? Answer questions, earn points and help others
