Question about Genie Company Genie Garage Door Opener Safety Sensors Photo Cell Set
Garage door opener not working
Door won't close; one safety sensor displays flashing red light but is not obstructed
  • 2,129 Answers
Sensor must show steady light to close circuit and let opener work. If aligned, then there is a loose or broken wire. Try reaiming first to get steady light. Then check all wires . Another way to test and prove that is the issue is if u hold down the wired button at ur back door and the opener closes, then it is sensor issue. Good luck.
Posted on Apr 11, 2015
Craftsman 1/2hp garage door opener works fine to open door but to close I have to hold button down. If not, door won't move and lights flash 10 times.
10 flashes mean sensors are obstructed... something is in the way of the door or they are not facing each other. Clear the obstruction or realign the door and it will work.
Aug 27, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Garage door opens about 4 inches, stops, then goes back down. No flashing lights at all. One sensor light is green, the other is a steady yellow. What's the issue?
something may be obstructing the door, so pull the red emergency release handle and try to pull the door manually.if you cant move it manually, call for professional help
make sure all snow and debris are clear of the area where the door closes
if there are no obstructions, manually set the adjustment controls on the back side of the opener panel. weather can sometimes change the amount of force needed to open/close. adjust the setting with a screwdriver to no more than 260 degrees, about 3/4 of a turn
Feb 09, 2013 | Craftsman Garage Door Opener 1/2 HP Chain...
Light flashes on gargage door and it will not close, but it opens
Maybe it's the safety device that prevents the door closing if there is an obstruction. Many of these have a reflector mounted near the floor on one side and an infrared light on the other side. If either end it obstructed, the door won't close.
Oct 02, 2012 | liftmaster Chamberlain Garage Door Opener...
After a brief power outage my Marantec 4700 garage door opener has problems opening/closing. When opening it stops at the fully open position and the lights blink, when closing it automatically reverses...
This is not a sensor issue, I have a similar problem, sensors work fine, garage door is still fully functional, all operations, including safety sensors work properly, just the overhead lights flash. I suspect there was damage to the power board due to a power surge, going to order a replacement to see if it works, will let you know how it goes.
May 14, 2011 | Vacuums
I have a liftmaster Model 1240. Door will open by remote or wall opener. The door will only close while holding wall opener button down. If i try and close via remote, light starts blinking and door...
The only thing that will cause the main light to flash 10 times and the door to reverse to the open position is a sensor problem. Make sure the light on each sensor is on and not flickering ever so slightly. Make sure they are not moving when the door starts to close. Lights on sensors should not blink. One light should stay on constantly and the other sensors light should go off when you block the sensors.
Jan 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman 1/2hp garage door opener (HBW0777 year 1994). It won't close and goes back while blinking 8 or 9 times. Transmitting sensor (red light) is blinking 3 times (even i hold the two sensor...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. If the transmitting sensor light is blinking it is bad.
Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door will not open or close with remote
What does a normal remote do with the lights?
Is yellow and green normal?
Aug 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wont open or close/lite flashes and clicks.
two problems. recode your remote control. are led lights on both sensors. clean lenses. aim at each other. should cure.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Genie Company Genie Garage Door Opener Safety Sensors Photo Cell Set Logo
233 people viewed this question
Top Genie Company Building Materials Experts
chrisheman
Duff Howell
Ian Lulham
Ian Lulham
Level 1 Expert
Are you a Genie Company Building Material Expert? Answer questions, earn points and help others
