Question about Boating
65 hp evinrude removal of flywheel
Best way to remove flywheel
    New Friend:
  • 17 Answers
Remove the Flywheel nut, Get a steering wheel puller or a harmonic balancer puller that has a pin in the bottom. ( I have both and the official OMC one the OMC is the best) . Get the proper length bolts and make sure they go far enough into the flywheel to engage all the threads but not too far as to damage the coils. Make sure they are screwed in evenly. Then tighten the puller while holding the flywheel ( you can use a screwdriver by the starter or a flywheel holder)and when it feels tight hit the top of the tightening bolt (This is the one in the center of the puller with a hammer. that will "pop" the flywheel. if it doesn't come tighten more and hit it again. The shock of the hammer will pop it off. If you don't shock it, it may not pop off the taper.
Here is a picture of the OMC puller and a Steering wheel puller the OMC is the black one.
65 hp evinrude removal of flywheel - 65-hp-evinrude-removal-flywheel-14w5ramivvvc2eiejtue2vl2-1-0.jpg
Here is the proper bolt. Official OMC tool bolt
Notice the thread length is limited as this is a shoulder bolt made especially for pulling OMC flywheels. That prevents them from screwing in too far and helps keep them even.
Posted on Apr 20, 2015
    Champion:
  • 254 Answers
A steering wheel puller will work, just used the right size bolts in the 3 holes on top after you remove the flywheel nut.
Posted on Apr 18, 2015
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
How to remove the twist grip on 15hp evinrude outboard motor?
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82 Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
Nov 01, 2015 | Boating
Pull the fly wheel on a 84 40 horse evinrude
remove the large nut frm the top of flywheel,making sure not to turn motor backward , then get a flywheel puller that fits .bolt that on and tighten the center bolt giving the top of it a rap with a hammer when really tight . might have to do it again after getting it real snug again.
Sep 26, 2014 | Boating
Wont start
Check the blade bolt is tight, if the starter kicks back it may have sheard the flywheel key, to check this you will have to remove the starter and flywheel.
Apr 16, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Will not crank, starter works fine. 40 hp evinrude, seems like the engine is locked up but the pistons do move a little when i move it by hand, need answer.
remove spark plugs and you should be able to rotate the flywheel easy ! then try starter to spin over , if not then remove starter and check the brushes inside etc ! check solinoide ok ! check wires ok !
Oct 02, 2011 | Light Outboard Motor Boat Bass Fishing...
How to remove starter from 1983 30hp evinrude OMC
I just read up on the removal of your carb, It says to remove the flywheel to get more room, and then the carb, the left side bolt is harder to get to but it can be done. Only get 1/6 turn of the wrench, remove the fuel line, and be careful not to lose any throttle parts. Hope this helps.
Apr 15, 2010 | Boating
How to set the points on a 6hp 1970 evinrude.
remove flywheel . points setting is .20
Mar 05, 2010 | Boating
Boating Logo
258 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
