Question about Vacuums
How to remove the belt - Vacuums
    New Friend:
Most vaccumeing have 4 to 5 screws holding the bottom plate remove plate pull out roller . Slide it off the roller and motor replace with new belt by first slide belt around motor arm then roller pull roller into place then roll the roller 3-4 times to insure it's in the right spot. Replace bottom plate
Posted on Apr 16, 2015
How to replace belt on a bissell 66e1 pro heat lift off pet carpet cleaner
There are two belts on your model. Remove the screws on the end cap assembly on each side to remove the assembly to gain access to the belts. Remove the screws holding the brush roll assembly to remove and replace the belts.
Jan 08, 2017 | Bissell Vacuums
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
How to change belt on hoover runabout 44258-930?
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a hoover u 4266-940?
Hello! Below are instructions for replacing the belt on your U4266940.
Hope this was helpful!
Jun 20, 2014 | Hoover Soft Light U4266-940 Bagged Upright...
Vac motor runs but belt wont turn
its time to check and/or change your belt.
to do this you want to remove the two screws on the top casing and remove the cover.
There are detailed belt change instructions on a sticker under the top casing on how to remove the brush and belt etc.
Make sure you have the right belt, it is the Eureka EXT-U or U belt I believe that the number for the belt is 61220 and they come in packages of 2.
Good luck
Nov 15, 2010 | Eureka Power Plus 4703D Bagless Upright...
Need directions for changine belt for brushes
There is a door on the side pop it off remove the old belt and simply slide the new belt on. Over the motor shaft first then the roller brush end.
Apr 12, 2009 | Vacuums
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Jan 19, 2009 | Hoover Windtunnel Supreme U5280-900...
Kirby g4 belt replacement
Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
Dec 18, 2008 | Vacuums
Found my problem...
to replace the pump belt , make the machine safe ,
Remove the pump belt cover Turn the machine over ,You must remove the floor brush,
You will see two red retainers on either side of the machine ,remove the screws which hold these on ,remove them .
pull the pivot arm out of there slots remove the brush,you will see the brush belt remove all these ,
you can then feed the pump belt over the end of the pump and motor spindle .refitt in reverse order
All this should be in the instructions, Could luck
Oct 20, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
82 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
