Question about Kenmore Elite 24" Built-In Dishwasher with Ultra Wash HE
What does code f2e2 mean - Kenmore Elite 24" Built-In Dishwasher with Ultra Wash HE
  • 59 Answers
F2E2 is a failure to communicate with the user interface board. This is caused by either a faulty user interface (the board with the buttons) or quite commonly it can be the main wash pump as the main control uses the same wires to communicate with both and a bad pump will interfere with that communication.
There is no easy way to tell which one is the problem but i have found that any evidence of a leak on to the wash pump will cause it to fail.
Posted on Jun 16, 2015
Error code f2e2, will not fill, run. How do I reset it and place into diagnostic mode. The paperwork is missing from front kick panel
I am guessing this is a Sears Kenmore Elite Dishwasher were dealing with ?? If so follow below if Not what are we talking about?
The FUNCTION CODE 2 is for a USER INTERFACE issue. The PROBLEM CODE 2 can be:
User Interface cannot communicate with main control Panel. (A).Unplug dishwasher or disconnect power. (B). Check connections of gray wires between LCD display module and P12 connector on the control Panel:
Loose User Interface connection. (A). If connection(s) loose, then reconnect.
Faulty User Interface. (A). Disconnect power and replace LCD display and console.
Always unplug or de-energize electrical equipment before removing covers or attempting service. Be careful and wear appropriate hand protection when working around sharp metal parts.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a technician.
I researched this a little bit and You need to check for any signs of water spray a cheap hose clamp seems to be the cause of a lot of this problems also corrosion some DIY individuals have removed the cable to the main control panel found corrosion and cleaned it up now working fine while control panel has a fault in Communication their is No Diagnostic Mode Available because of lack of communication , hope this helps
May 18, 2016 | Dishwashers
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
What does code F2E2 mean on the display
My Kenmore Elite dishwasher is showing code F2E2..What ...
www.shopyourway.com > Agafia Reutov > Questions
The F2E2 error can be frustrating. The problem is the User Interface is not communicating with the main control board. This error is mainly caused by a poor ...
Kenmore elite service code f2e2 ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Te hose came off the bottom of the washer, then I got the service code f2e2. ... I have a kenmore elite dishwasher model 665.1396 ERROR CODE F2E2 ?
Oct 22, 2015 | Dishwashers
My kenmore dishwasher is flashing E2 F2 what do I do.
Since you didn't add the model number for your dishwasher, I can't detail any specific fixes. The F2E2 error usually means that the display panel (user interface panel) isn't communicating with the main control. This could be a sign of a bad panel, a wiring problem (loose wiring harness or the wrong panel being installed) or moisture inside the dishwasher. Unplug the dishwasher then you can check the unit.
A common source of the moisture problem is actually loose hose clamps at the pump. That lets water get into the control wiring. The error will reset after the entire unit dries (2+ weeks). You might find the moisture when you pull the unit out of the cabinet for a built-in model. For the other problems, you open the cover and check the grey wires between the LCD panel and the P12 section on the main control.
If your dishwasher is under warranty or are uncomfortable with electrical wiring, you should contact Sears for service before opening the cover to access the wiring.
I hope this helps.
Jan 28, 2015 | Kenmore Dishwashers
How do I get error code f2e2 off my dishwasher?
"F2 - A water leak, which if detected will stop water from entering the dishwasher via the inlet valve. You will probably experience the dishwasher not filling properly during a cycle. Possibly caused by a faulty water level indicator, you can also try cleaning the filters and drain if you notice a lot of standing water remaining in the dishwasher basin."
"Look in the bottom of the unit. Something has it stuck, like food."
sorry if this doens't solve your problem. This is what turned up with your keywords in a quick search engine query.
Sep 18, 2014 | Kenmore Dishwashers
Dishwasher will not start
Unlock dishwasher if locked by holding heated dry button for about 4-5 seconds next quickly hit the following buttons in successive order heated dry, normal wash heated dry then normal wash this should run diagnosis of the unit. Wait about2 minutes then press the cancel/drain button this should reset it and restore operation be sure to check that water supply is on and the drain is clear or you may get the code again.
Dec 07, 2013 | Kenmore 24" Built-In Dishwasher with...
Code error
If the Nokia 7210 says Code error means you entered the wrong code,It's Network Unlock code or security Unlock code?Network unlock code means you can have only 5 Unlocking tries ,if you missed means it get hard locked ,so cannot unlock using the unlock code,get the correct Unlock code from the site
Unlock-free.com/nokia/nokia-7210.html and Unlock from Network lock,You need to unlock from security or password lock means get the master reset code for Nokia 7210 at here and reset it.You can also try default code 12345 or 1234 or 0000 if not works means get the master reset code and reset it.
Dec 12, 2011 | Nokia 7210
My phone is asking for an input np code
It's asking for NP Code means Network provider code,that means Unlock code,If the Mobile locked to other Network means you trying to insert other Network Sim means it asks for Unlock code or NP Code,Unfreeze Code,subsidy code,Special code,NCK code,MEP Code etc...It depends upon the Brand of Mobile..so specify the Mobile Brand ,model,network,country it locked now,IMEI number and get the Unlock code at
Unlocking4u.com and Unlock it...
Jun 04, 2011 | Cell Phones
Kenmore Elite 24" Built-In Dishwasher with Ultra Wash HE Logo
251 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
