Question about Hitachi Televison & Video
Blue power on light takes longer and longer to warm up (40 mins now).when powered up tele can be switched on and off with no issues (only happens when its cold).
L42VC04UB model
    Top Expert:
  • Hitachi Master
  • 75,452 Answers
Check and replace the CRT base connecting Socket. It is faulty. This can be located at the CRT base card. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 11, 2015
On at the mains cant switch on the tele
Are there any lights on anywhere on the tele? Also what make and model is it ?
Feb 20, 2015 | LG 42LC2D 42 in. LCD HDTV
Samsung LE40R73BD. takes 15mins to start up
Power supply board is dead.Replaced the power board will solved this problems.Buy a refurbish power supply at Shopjimmy.com,Ebay.com.
Feb 10, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My tele klicks for about 3 mins before coming on
sounds like the power supply board is failing. VERY common problem with all samsungs.
Nov 11, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Inserted blue ray disc into cold ps3, now dead dead dead
Does it have a red light in front or nothing? If you don't have anything then your power supply has went out and you can pick one of those up for 40-50 dollars on eBay.
Thanks,
Ced
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Lens Error and Proper switching on Problem
Same problem for me. Try below one. Its working!!!
Press the power-on button, and at the same time Press and hold the shutter button down
Mar 11, 2009 | Cameras
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Dec 19, 2006 | Electrolux EOB6632 Electric Single Oven
Televison & Video Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
