Question about Samsung UN60D6450 60 3D-Ready LED-LCD 1080p HDTV
The left half of my screen is green. There is no option for a factory reset and the SCREEN tab on the Picture menu is blacked out. How can I fix this?
    Top Expert:
  • Samsung Master
  • 74,383 Answers
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Apr 11, 2015
  • Samsung Master
  • 681 Answers
Hi Jaison,
Your problem seem to be due to a bad TCon board. I do'nt know if you can open the back cover and reach the TCOn board. Check the connectors and flat cables of the defective side. If you can not do it, please consult some repair Technician.
To recover password to unlock screen
Samsung Galaxy Tab Hard Reset GT-S6102
1.press upper voume button + menu + power button
2. rebbooting screen will appear with options like android system recovery, android system recovery rebbot system, apply update from sdcar, wipe data/factory reset, wipe cache partition...
3. choose "wipe data/factory reset" option
4. select yes and delete all.... select options through volume key
5. press rebbot now
6. handset formatted and back to normal state
7. successfully done
Jan 10, 2014 | Samsung GT-S6102 Galaxy Y DUOS - Unlocked...
Toshiba 61H70
Does the rest of the viewing picture looks like the picture below?b66a18b.jpg
Jul 04, 2008 | Toshiba 61H70 61" Rear Projection...
Tip
How to enter Factory settings on GNR TS700 (Black/Silver) 17" LCD monitor
- Press Power to turn screen off
- Press and hold Select/Auto
- Press Power to turn screen on. LED will be Orange instead of Green
- Release Select/Auto
- Press Menu
- You will see 2 additional options (Factory 1 & Factory 2)
- Exit as normal
- To return LED to Green, Power off then Power on
To reset colour:
- Choose Factory 2
- Choose Auto Color1
on Dec 31, 2009 | Computers & Internet
My flat screen intermittently darkens in the top left hand quadrant
make this test and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Jul 31, 2013 | Televison & Video
Screen on toshiba 50HP66 is black with no audio
reset the TV.follow this steps and fix it. God bless you
Jul 31, 2013 | Toshiba Televison & Video
Half screen is blank 42lg20 or 42lg50 when
This is likely to be the T-con board. If the entire screen glows but you have no picture on the second half of the screen then it is the main board, not the backlight inverter. If the screen is half picture and half gray it is the T-con board.
Replacement of one of the above will fix the issue.
Please rate if this helped :)
Mar 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Screen dim, black has green in it, contrast and brightness = shin
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
Apr 03, 2010 | Samsung Televison & Video
I have a 05 jvc tv 32 inch . I lost my remote temporarily-used the menu on the actual TV to set a timer for the TV to go OFF-turned it on this AM and now i have half of my screen filled with this overlay ....
Try Reseting It Unplug It For 30 Seconds And Then Release And Plug It Back In Once You Go To Turn It On Hold The On/off For 10 Seconds and Then Release. This Will Hopefully Restore The Factory Setting And You Can Determine If Its A User Setting Or Hardware Problem.
Jan 23, 2009 | Televison & Video
It only shows a black screen
I was having the black screen problem intermittently (of course when you really want to take a picture quickly). I downloaded v1.1 of the firmware from olympus (via the Olympus Master 2 program) and the black screen problem has not reoccurred yet. Hasn't been tested over a long period of time yet, but that seemed to fix it.
Jul 12, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Samsung UN60D6450 60 3D-Ready LED-LCD 1080p HDTV Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
