Question about Miscellaneous
How much land is contained within an area of 660ft x 60ft?
  • 352 Answers
0.368 hectare
0.909 acre
3679 sq meter
0.003679 sq kilometer
39600 sq ft
5.702 million sq inches
Posted on Apr 11, 2015
What are the clues on topographic map that it represents a high rainfall area?
Topography is about how steep or shallow the land is. it will not contain any data about rainfall... perhaps streams and rivers... not rainfall, you are looking for a climate map not a topo map, google it!
Jul 31, 2014 | GPS
Heat coil burt out
Leonard,
Thank you for asking me directly to help you with your problem. However, either the question you are asking is not within my area of expertise (I am an automotive repair technician), or the question is incomplete and does not contain enough information for me to help you.
Dec 31, 2011 | Cars & Trucks
I have a sony x8. i dropped it off the counter and it landed in the dogs water bowl. i have taken the battery out and left it to dry. i was wandering if there is anything else i can do. i have only had the...
You could place to phone (taken apart) into a airthight container (food container) and fill it with rice. the rice absorbs any moisture / water. leave it in a warm area for few days to properly dry out.
should work after that.
Jul 07, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Where do you check the transmission fluid?
PERFORM AN ELIMINATION OF ENGINE FLIUD CONTAINERS TO ACQUIRE THE TRANSMISION CHAMBER
The vehicle should only have an engine oil compartment, radiation compartment for antifreeze/ water, power steering fliuds, a water wiper blade spray dispenser compartment, and finally the transmittion fliud container area all situted within the engine entrapment area. Usually, opening the engine for the first time would require observing the fliud compartments that are identifyable from the remaining engine chambers. Observing closely on the fliud container should have written descriptions of what is expected within compartment. For example, the water fliud containers for wiper blades would usually have written lables as wiper blade fliud container, radiantion container would usually have the antifreeze demarkation logos visibly observable when engine is opened. Rely by elimination methods to ascertain the transmission fliud compartment. For example, once antifreze container, wiper water container, engine oild container, power steering fliud containers have been identified, the most like only remaining in the engine would be the transmition fliud compartment. Alternately, every fliud container within the vehicle engine is situated at separate areas. For example, the only fliud container closest to the transmittion chamber is the engine oil compartment. The vehicles usually require more engine oil than transmission fliud. Between both fliud containers, the smallest chamber for fliud oil is usually for transmission perposes in the absence of hydraulic fliud compartments with newer vehicles.
Jan 22, 2011 | 2000 Oldsmobile Alero
Antifreeze
Do this only if the engine is cold.Set the heater on.Remove the coolant expansion tank cap , place a suitable container under the radiator area , Look under the radiator (bottom rear side) for a plastic screw and loosen this by hand . Move swiftly not to get wet.Remove the bleeding screw on the top radiator hose.Flush the system with a coolant flush solution if the coolant is really dirty.Refit the drain plug , refill anti freeze (check with your parts supplier for the recommended ratio for your area(or your dealer)and top up with water.Run the engine and close the bleed screw once water comes out and replace the cap.Warm the vehicle up and remove the cap when it has cooled down again.Check coolant level and top up.Reset the heater off(if its summer there.)
Oct 02, 2008 | 1999 Land Rover Discovery
2002 freelander coolant leak
My coolant leaked out and on top there is a large hard plastic container, I had to replace it, that stopped my coolant leak.
Sep 26, 2008 | 2002 Land Rover Freelander
Miscellaneous Logo
67 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
