Why is picture and sound breaking up on new you view box?
Got a double picture on my TV which is going through a bt u view box
If you are not getting a tidy pic first thing I would check or change is scart lead make sure they are firmly in back of TV and your viewing box if so try another scart lead, the thicker the scart lead is the better they are apparently. Or if your using hdmi lead instead of scart try another hdmi port at back of TV as these ports tend to break easy in TV as they break off the mother board.
Apr 12, 2016 | Televison & Video
How to delete Page breaks in Excel
Move a page break Important To enable dragging of page breaks to another location in a worksheet, make sure that the cell drag-and-drop feature is enabled. If this feature is not enabled, you may not be able to move any page breaks.
To verify that drag-and-drop is enabled, do the following:
Click the File tab.
  1. Under Help, click Options.
  2. In the Advanced category, under Editing options, select the Enable fill handle and cell drag-and-drop check box, and then click OK.
  3. Select the worksheet that you want to modify.
  4. On the View tab, in the Workbook Views group, click Page Break Preview.
    2. Tip You can also click Page Break Preview za010181030.gif on the status bar.
    3. Note If you get the Welcome to Page Break Perview dialog box, click OK. To not see this dialog box every time you go to Page Break Preview view, select the Do not show this dialog again check box before you click OK.
  5. To move a page break, drag the page break to a new location.
Note: Moving an automatic page break changes it to a manual page break.
Delete a manually-inserted page break Note You cannot delete page breaks that Excel has added automatically. Adding manual page breaks, changing the page orientation, or adjusting column widths and row heights may affect automatically-inserted page breaks.
To delete a manually-inserted page break, do the following:
  1. Select the worksheet that you want to modify.
  2. On the View tab, in the Workbook Views group, click Page Break Preview.
  1. Do one of the following:
    • To delete a vertical page break, select the column to the right of the page break that you want to delete.
    • To delete a horizontal page break, select the row below the page break that you want to delete.
Note You cannot delete an automatic page break.
Jul 20, 2014 | Microsoft Excel 2010
My picture and keep on breaking up on some channel
If you have a good picture on some channels and the picture breaks up on others , it could be the input signal. What is the source of the input signal; i.e. cable, satellite, antenna???? Do you have a cable box? The problem may be with the box or with the provider's signal.
Mar 30, 2014 | Sony KDL-46S4100 46 in. LCD TV
Tv pops on and off suddenly after viewing for about 10 to 15 mins. this problem becomes progressively worst after prolonged viewing. as of today there is absolutely no picture and or sound.
Your symptoms exactly match this scenario: a component involved in picture & sound was failing intermittently, then progressed to a hard failure.
My suspect: a power capacitor in the power supply. They sometimes fail this way - when the dielectric breaks down completely, then the power supply fails, causing no pic/sound.
Fix: replace power supply (or the specific capacitor, if you can determine which one died).
Oct 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
PICTURE BREAKS UP ON FREE VIEW OK ON TERRESTIAL
hello try retuning the free view see if there a software update for the freeview box. make your aerial connected to the tv securely and the scart lead is connected securely as well good luck
regards
shaun
Jul 25, 2010 | Hitachi Televison & Video
About 30 days ago I started losing the signal for CH 5 in Nashville, TN The strength is in the 80 to 90 range but the picture breaks up and the sound cuts in and out. Have new converter boxes,...
Have a close look at the cables between the converter box and the television set. Perhaps one is damaged by a tight bend or has a damaged connector.
Nov 02, 2009 | Emerson Televison & Video
Hdmi audio not working when conected to tv
Follow these steps to change the audio output settings for the HDMI option.
  1. Follow steps 1 through 8 above.
  2. From the Windows Vista™ default Start menu, click Control Panel.
    View Picture
  3. In Control Panel, using the default Control Panel Home setting, click Hardware and Sound.
    View Picture
  4. In the Hardware and Sound window, under Sound click Manage audio devices.
    View Picture
  5. In the Sound dialog box, click to select Digital Output Devices (HDMI).
    View Picture
  6. Click Set Default, and then click OK
    View Picture
Note: The default audio setting for your notebook is Speakers / Headphones.
You must change the audio output back to the Speakers / Headphones option for the computer to once again be able to use the internal speakers and headphone jack.
Sep 24, 2009 | Gateway T-1620 Notebook
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Picture sixe reduced and picture breaks up with converter box
You can change the way the channels can be displayed/viewed by a video setting, consult manual. When pic breaks into pixels and sound goes it's usually a reception problem so you'll have to adjust the antenna facing a direction that makes that channel come in clearly. It helps to experiment with positions and antennas.
Nov 17, 2008 | Insignia Digital-to-Analog Converter for...
BLANK SCREEN
Your camera has defective CCD Imager and needs to be replaced. Sony will repair it free of charge. Click Sony website for details.
Regards,
Aug 14, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
