Question about KitchenAid Food Mixers
Mixer doesn't work after the 5th speed - KitchenAid Food Mixers
    Top Expert:
  • KitchenAid Master
  • 10,875 Answers
Mixer doesn't work after the 5th speed - 25640734-5sp5orn0xnhdqraxk0v0421v-3-0.png
Posted on Apr 14, 2015
  • KitchenAid Master
  • 1,267 Answers
That's not the sort of problem you are likely to solve at home. There is a speed control pcb and a speed sensor involved, it's not mechanical like the other old models. Best you contact Kitchen Aid and find out where your closest authorised service agent is.
Stand mixer doesn't work after the 5th speed
Apr 11, 2015 | KitchenAid KP2671 Professional 6 Series...
How to fix a kitchen aid mixer that does not turn off
The answered suggestion on this post might be able to help you:
Doesn actually turn off Mixer
Mar 07, 2015 | Food Mixers
250 watts k45ss classic stand mixer doesn't run
My first guess would be the speed control plate. It has three screws in an upside down triangular shape. The two screws on top control and adjust speeds 1 thru 6, and often times just one screw being out a 16th of a turn will shut the mixer off completely. I would venture that when you were removing the two stud bolts you moved the adjustment screws on the speed control plate. Remember that even a slight movement can shut down your mixer, take a phillips screwdriver and turn the top left screw one quarter turn while the machine is on, it can start on you so don't be shocked and jump with a loaded screwdriver in your hand at the back of an electrical device, stay calm, if no start then try the left screw a quarter turn, if it does not start go to a half turn on each screw, if still no start turn thr screws back to the start place and try the bottom screw a quarter turn left and right, if you do not start by now, then something is wrong in another place, go back to the brushes and take them out and check how you put them in, these are the two most common problems with a no start mixer. If this does not fix your problem or get the mixer to start please come back here with more info. If you motor raced in the first place then I would suspect the phase control board, but when it came back to normal speed it leades me away from the phase board. When the phse control board goes out the mixer only works at high speed. So please let us know so that we can help further.
Mar 28, 2013 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid wont start
The possible problems could be in no real order>>>
1. your power outlet in your house
2 the power cord to the mixer broken or shorted
3 the speed control plate inside the mixer needs adjusting or replaced
4 the carbon brushes inside the motor head of the mixer need replaced
5 the armature a motor part
6 the stator a motor part
The first four are easy fixes the last two will require a full tear down. but there are lots of things to test first. let us know.
Feb 22, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Mixer only runs at one speed
if it runs only at high speed it needs a new phase control board if the mixer is post 1978, if the mixer is pre 1978 then you will have to replace a capacitor on the end of the power cord inside the mixer. if the mixer only works on one speed that is not high speed then you need to adjust or replace the speed control plate on post 1978 mixers and the capacitor on pre 1978 machines. Hope that helps
Jan 30, 2013 | KitchenAid Food Mixers
Mixer doesn't work on all speeds
First the K45SS does not have a hall effect sensor. the pro series the epicurean seines and the pro series 5 use them, The K45ss system uses a phase control board a speed control plate and a governor for speed control. the governor rarely goes out the phase control board is a likely culprit but the system would work only in high gear if it was bad. I agree with the guest above in that it sounds like the retaining nuts on the adjusting screws of the speed control board have worked themselves loose and the adjustment screws themselves have vibrated out of proper position.
Sep 20, 2012 | KitchenAid K45SS Classic Stand Mixer
I have a KM800 and the speed setting doesn't work properly, on slow it will go fast then slow and doesn't speed up and slow down as it should. is this repairable, as it's bloody annoying when you disa
Hi Emma,
Not going to be much help here to be honest. We have the KM020 and this is the only problem we have had with heavy machine use in 4 years - and a minor issue at that.
This place is good for spare parts http://www.buyspares.co.uk/
If you're in the UK, you can call this number 02392 392 333 and give them your post code, they'll let you know who the local service agent is.
All the best,
Dec 17, 2011 | Kenwood KM800 Major Classic Stand Mixer
I have a Kitchen Aid k45ss that was dropped a few years ago. I works fine but the speed switch doesn't want to stay in the off position so we have to unplug it. I opened the unit and the switch...
When you said "the speed switch doesn't want to stay in the off position", you meant to
say "the speed switch in the OFF position does not turn OFF the mixer", or "the speed
switch physically cannot be moved to the OFF position"?
In any case, try to adjust the mixer speeds.
Obtain a copy of the K45SS Repair Part List from Kitchenaid.com.
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 21, 2011 | KitchenAid Food Mixers
The speed control doesn't work well
This problem could be due to a worn or broken speed governor. this part is located on the motor shaft of the unit and works by way of centrifugal force. This however when gone will usually make the mixers speed go up and down, not just one speed. The most likely cause of this problem is the main control board. if this has become faulty, it can make the mixer stop completely or in your case, run full speed when turn on. part number for the board is W10119326. this part can easily be changed by disconnecting all power and removing the back end cover. Once removed make note of the adjustment screws at the bottom of the board. As these are your motor speed adjustment screws, and can be very finely tuned. Once these and the spring has been removed. you can now replace the board. Hope this helps
Thanks
Nov 01, 2009 | KitchenAid K45SS Classic Stand Mixer
West bend stand mixer # 41039 dial won't turn
If the mixer does not work on all speeds, then check motor wiring and control board.
If the mixer is less than one year old call manufacturer at the number listed on the owners manual.
To get parts for your mixer you can contact West Bend Appliance Parts - Bettervac 1-800-675-9491
Dec 08, 2008 | West Bend 41125 Hand/Stand Mixer
Food Mixers Logo
162 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
