I am retired tech but never worked on Bosch.Washer not spinning or draining after heavy load. Pump tested ok, Drain clean. fills and turns in wash
  • Washing Mach... Master
  • 5,323 Answers
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Posted on Apr 11, 2015
  • Rafael
    Rafael Apr 11, 2015
    Hi Jhonny, The machine is a Speed Queen LWS05NW (mechanical, top loader). The machine washes and gets stuck on Rinse/Spin cycle. It is spinning for 3-5 seconds so motor and drum are ok. The Door microswitch which is opporated by the door hinge is fine. The manufacturers don't seem to have the Technical Manual to download.Any further pointers?
WFTC3200 not draining or spinning after heavy load was put in. Wash cycle fills and drum turns. Drain and hoses clean. Pump tested ok. Locks n does nothing no error code
Apr 11, 2015 | Washing Machines
Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jul 02, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Washer stopped after wash. Would not drain or spin. Will fill.
Hi, can I get a Model# and make so I can try and assist you?
Vic
May 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch wfmc3200 will wash but will not spin or
hi, this is a drain pump motor issue. i would check the wires leading to the drain pump and the control board. make sure the pump wires are connected and the control board wires as well. if the wires are connected, this will rule out a communication problem and confirm pump failure.
You can also do a break point test with a multimeter on the control board to make sure the control board is working correctly.
Concerning the locked door(washer locked)**. if the door is locked, this may be a control fault. test the door lock mech for its operational value to confirm this as well.
May 14, 2009 | Bosch WFMC 3200 Front Load Washer
Front loading washer does not advance past the rince cycle
Check and clean filter, it is usually located behind a plastic panel at the bottom front of the washer, remove cover and unscrew the filter cover anti clockwise, pull out and clean, replace and test, if it still does not drain, then possibly pump blocked or faulty.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
