Question about Makita Fuel Line; Dpc6400 Ope - MKA 965 404 911
Starts but onley runs for 30 seconds - Makita Fuel Line; Dpc6400 Ope - MKA 965 404 911
  • Makita Master
  • 2,760 Answers
Yes this is a common symptom of a fuel delivery problem , most likely caused by a dirty fuel filter or dirty carburetor , but sometimes a bad fuel line as well (cracked)
Posted on Jul 24, 2015
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
Sanyo PLC-XT10A shuts off after 30 seconds
That is really odd maybe when its upside down something is barely coming loose or a fan is getting blocked?
Dec 08, 2012 | Sanyo PLC-XT10A
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
Starts but onley runs on choke
dirty jets in the carb will cause that
May 15, 2012 | Garden
Bike starts onley running on back cyl. front one cold has spark on both and comp about the same ,wandering about front carb any ideas
check to see if your front spark plug is wet when you run the bike. If it is then your spark might not be strong enough. this could be a bad coil or ignitor. If your plug does'nt get wet then clean and rebuild your front carb. check to make sure your itntake manifold is not cracked or dry rotted and causing a vacum leak.
Aug 08, 2010 | 2002 Suzuki VS 800 Intruder
Runs for 30 sec then stalls
go to ebay and fine yourself a cheep fule computer there about £30 second hand i think yours has just packed up and its making the bike run very very ritch
May 24, 2010 | 1994 BMW K 75 S
Starts running for short time then stops
Sounds like the compressor has fused windings. The only way is to get it checked by a refrigeration technician. It may only be a start relay.
Regs,
Hawk
Jan 16, 2010 | Engel Refrigerators
Adjust throttle speed
YES YOU DO BUT YOU NEED A TOOL THAT ONLEY SHOPS HAVE LET ME KNOW IF I NEED TO TELL YA WERE TO TAKE IT
Oct 10, 2009 | McCulloch Garden
It starts fine, runs 20-30 seconds, runs rough,
check the actual fuel line. Also is it fuel injection or carberator
Aug 03, 2009 | 1992 Dodge Power Ram 50
Makita Fuel Line; Dpc6400 Ope - MKA 965 404 911 Logo
143 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
