Question about Garden
How do I change the hydraulic fluid? - Garden
    Sergeant:
  • Garden Expert
  • 187 Answers
Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one.A short description of the events preceding the beginning of the problem is also helpful.
The NOT SERVICEABLE UN-TRUTH.
The Huskvarna YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams for most Huskvarnas is here: http://www.m-and-d.com/Hydro-Gear_parts.html
MTDs use Hydrogear trannys also. Go to the site and enter 618-0319 in the search box. It will bring up a selection of MTD transmissions.
Sears Craftsmen mowers also have trannys from Hydro-Gear.
The best lawn tractor Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like Mobil 1). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Most of them are made by one or two manufacturers. Tuff Torq makes a lot of them, but not the Huskvarnas. They do make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, an untruth. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. They have a lot of good general info for anyone rebuilding their tranny.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like Mobil 1™). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black drain plug on the top, if they do not have the add on reservoir. You have to remove the tranny from the mower (not a difficult things to do, it takes about 30 min). Pull that black plug (I used a 1" putty knife to pry mine out) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out; clean it and replace it. It may fall out while the tranny is upside down.If anything else falls out, you have a broken tranny and will have to take it apart.
When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
Tuff Torq Lawn Garden
Posted on Apr 11, 2015
Looking for diagrams on hydraulic system on a Bobcat 623 versa handler front axle. grinding noises are caused by what?
Fluid level? last time fluid and filter changed? Color of fluid? I'd guess the hydraulic pump is not getting enough fluid due to level or blockage. Possibly a crimped hydraulic line. Could also be a Bad wheel bearing or gears or lose Hydraulic motor so gear is not in proper position.
You "may" be able to find manual here: https://www.manualslib.com/
Or: http://www.manualsonline.com/
Feb 10, 2018 | Cars & Trucks
Changed hydraulic filters now hydraulics don't work?
Sometimes with hydraulics you need to "burp" any air from the system, though they tend to be so-called self bleeding. Try filling the filter with fluid and check that the pump has fluid in it to get it pumping. If the fluid was drained from the pump and it has air in it, it won't do anything. Get some fluid in it and it may start pumping.
Apr 04, 2017 | Garden
My recently purchased used MT180HD tractor will not move. I replaced all hydraulic oil,checked the clutch,and adjusted linkage. What next??? Are my hydraulic pumps bad?? Can a mechanical transmission be...
hi there joedorava
is there input to pumps , are there any leaks in the system either oil / air
have you purged all the air from the hydro units and wheel motors
if air is entraineed in oil , you may get alot of noise from caviatation in the pumps and wheel motors also heat , and vibration and no movement until all the air is gone
top up oil to correct level
caviatation can be quite destructive on pumps etc
i assume you used the correct hydraulic fluid for the unit in question
have you checked changed hydraulic filters when changed hydraulic fluid ?
other than that cant give any more info
cheers pauly46
May 25, 2011 | Diesel Compact Tractor 4x4 20hp Machine ...
I just bought a 2005 maserati quattro with 18000 miles, how often do i need to change the hydraulic clutch?
You should get 45-50k out of it, depending on how hard you drive it. (The fluid needs changing every 3 years)
Mar 23, 2011 | 2005 Maserati Quattroporte
How to change front wiper motor on 1996 eagle vison
  1. The observation with your vehicle implies mechanical malfunctions likely caused by insufficient, clogged, or burnout lubrication fluids. Since the component parts experiencing malfunction are observable at significant vehicle areas like power drive trains, several conditions are likely factors to driver's suspicion. For example, the drive train of significant mechanical sprockets linked at joints making propulsion possible with the control lever situated at drivers seating area is significant reason of concern. First, the driver's lever control functions hydraulically as modern improvement made possible with fluid lubrications, and several absorptions chambers. Once, an engineered hydraulic mechanical lever is realized to dispense manual contact requires inspections. First, a mechanical inspection to ascertain the conditions of constutuents providing hydraulic should be made on the vehicle. The possible outcomes include findings of an absence of faulty turbines implying no wear had occurred. Second, the observation findings may ascertain a burnout fluid that may require replacement procedures. For example, burnout hydraulic fluids usually may require cleaning draining, cleaning the residue slug from turbine areas making possible replacement of newer fluids. Hydraulic fluid conditions usually may require resistant variety that performs under overexerted conditions. For example, the fluid type may vary depending on the task requirements of the vehicle. Also, the type of condition expectations of the vehicle would require frequent hydraulic inspections.
Jan 22, 2011 | 1996 Eagle Vision
How to change a faulty throttle on a 2004Kia Optima
Jan 22, 2011 | 2004 Kia Optima
81 corvette can't getr a hard brake pedal . I have changed the master and bleed . still no hard pedal
Jan 22, 2011 | 1981 Chevrolet Corvette
Whay kind of hydraulic fluid do I use in a mtd split it wood splitter
You can use 10W AW hydraulic fluid or Dexron III automatic transmission fluid. It takes approximately 4 gallons. You need to change the fluid after every 100 hours of usage.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | Mtd Heavy Machinery
Hydraulic clutch problems
i have a ktm 125 wich all ktms have hydraulic cluthcs and i have the same problem as all these fellas even when im riding it just sucks right down all the fluid reply to me on X-KTMrida-X@hotmail.com ok thanks fellas
Jul 08, 2008 | 1997 Chevrolet S-10 Pickup
Garden Logo
179 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
