Question about Yamaha EF3000iSE Generator
Im looking for the valve settings and torque settings plus pattern on the head of a Yamaha ef2500 generator.
  • 11 Answers
SOURCE: 93 artic cat jag head torque pattern and specs
the best place to find it is the service manual. if not avail. i usually 1, tighten it to ~10-20Nm in a 'outwards spiral' fashion, ie start tightening from centre bolts outwards. 2, spiral tighten by 1/4 turn, 3, another 1/4 turn, and 4, final 1/4 turn.
Posted on Feb 13, 2009
  • 3567 Answers
SOURCE: hi im looking for the torque settings for the
45 foot pounds.
Posted on Mar 12, 2009
  • 3567 Answers
SOURCE: generator cover bolt pattern specs?
You can do the job yourself with no problem. No specific pattern for the side cover. BUT, get all the screws started then just bring them all slightly snug. Now tighten one screw and then go kitty corner and tighten another now drop down and pick a screw mid way between the first two screws and tighten it. Now do the kitty corner thing again and so on. As you know, the idea is to tighten the screws evenly around the entire cover.
As to torque, a 6mm screw gets 7 foot pounds or 85 inch pounds.
Realistically, no one ever bothers with torque on small screws. You will want to spend $15 to $20 and get yourself an impact driver to tighten or loosen screws. The tool is about 6" long and 2" in diameter and has a 3/8" drive on one end. Your socket set will fit it as well as screw driver bits. Just engage the bit into the head of the screw and strike the end of the impact driver with a hammer while twisting the tool to tighten the screw. This is the most valuable tool in my shop and I use one (Blue Point brand) that I got 40 years ago. They last well and can be used on any screw, bolt or nut that needs a little persuasion.
Please rate this solution as a "FixYa" if I have helped. Thanks!
Posted on Mar 23, 2009
  • 86 Answers
SOURCE: im rebuilding my warrior
if your using the old bolts, 35 ft/lbs. if new bolts, 25 ft/lbs. that will work just fine.
Posted on May 12, 2009
  • 53 Answers
SOURCE: Hello, I am looking for technical information
It sounds like it might be flooding or the timing might be out of wack. iw ould start by letting it sit for 30 minutes and try restarting the bike,.If it starts and then dies again have the throttle leaned a bit. If that is not the issue have the timing adjusted
Posted on Jun 16, 2009
Looking for valve settings and torque settings plus pattern on head....thanks
Edit this question to include year make model and engine size.
Apr 11, 2015 | Cars & Trucks
Looking for valve settings and torque settings plus pattern on head. any help appreciated
Garbage in- garbage out
No year
No make
No model
No engine size
No answer!
Head bolt torque yield
90% of head bolts are stretched when installed. If you have the torque settings, you can confirm this by checking the specs. If it says example, 90lbs feet, plus a quarter turn, this confirms they are gonna stretch once torqued.
In any case, yes, change those head bolts at all costs. DO NOT RE-USE THEM. Make sure to torque and in the order as well. do not use a random pattern when torqueing.
Nov 01, 2013 | 2002 Jeep Liberty
2001 daewoo lanos dual overhead 1.6 liter head bolt torque and sequence
  1. Tighten cylinder head bolts to 25 N.m (18 ft. lbs.). Tighten bolts an additional 70 degrees plus 70 degrees plus 30 degrees using angular torque gauge .
Oct 20, 2011 | 2000 Daewoo Lanos
Gererac 5500 XL with an EHF00945 11 HP engine What is the torque for the 4 head bolts?
Hi and welcome to FixYa, I am Kelly
I have tried going to the owner's manual and the parts listings
Owner's
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0208260.pdf
Part's listings
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Generator-Parts/Model-580327160/0247/0702250/P0208117/00007?blt=06&prst=&shdMod=
I even know the cylinder head has 4 bolts and the head part number is 21714
Yet nothing I have looked at tells me the actual engine number. With and actual engine Model Number I can answer your question without guessing which engine you have.
This appears to be a GN320 engine.
If that is the case... the torque is 44 Ft Lbs
Torque Pattern
Bottom left A
Upper right B
Bottom right C
Upper Left. D
CHECKING/ADJUSTING VALVE TO
ROCKER ARM CLEARANCE
Every 50 hours of operation, remove the rocker cover and
check the valve to rocker arm clearance.
When adjusting the clearance, the engine should be at room
temperature, and the piston should be at Top Dead Center
(TDC) of its compression stroke (both valves are closed). The
correct clearance is 0.05-0.1mm (0.002-0.004 in.).
Jam nuts 65-85 inch lbs
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Electrical Supplies
What type/size sparkplug should I use in my ef2500 yamaha gas generator?
The Yamaha EF2500 portable generator uses a NGK spark plug #BPR6HS. Just bought on this week at the local NAPA store to replace the old spark plug in my generator.
Tom in Lafayette, IN
Nov 12, 2010 | Garden
I am looking 4 the torque pressures (ft.lbs) on the main crank bearings, and rod bearings on a 2007 Ford 5.4 3 valve engine??? Gerry..............thank-you
mains - vertical bolts first 30 ft.lb. PLUS 90 degrees
pattern frt
8 7
4 3
2 1
6 5
10 9
side bolts
22 ft. lb plus 90 degrees
pattern frt
7 8
3 4
1 2
5 6
9 10
connecting rod caps cracked type rod-rod and caps must be kept in matched sets, recommend new bolts/nuts, spec is 32 ft lb. plus 105 degrees - torque each item to the correct torque then go back and do the degrees. these are torque to yield bolts and the procedure is very important.
Oct 02, 2010 | Ford F-150 Cars & Trucks
Torque setting cylinder head bolt 4 cylinder KIA sportage
I need the torque settings and pattern for a Kia Sportage 2.2
Nov 24, 2009 | 2001 Kia Sportage
1994 4runner, six cyl. putting rebuilt heads on, toyota head gaskets, new head bolts "tvs 10.9". Torqued bolts in pattern to 33 foot pounds. another 1/4 turn in the pattern. and into my next and final 1/4...
REMOVE 3 BOLTS MAKE SURE YOU HAVE THE RIGHT THREADS.IF BOLTS LOOK OKAY.YOUR BOLTS HOLES HAS DEBRIS OR OIL AND ANTIFREEZE IN THEM.OR YOUR BOLT HOLES IS STRIPPED.YOU HAVE TO REMOVE HEAD TO FIX THE THREAD PROBLEM.IF YOU HAVE NOT MADE THE FINAL TORQUE TO CRUSH AND SEAL HEAD GASKET THE. HEAD GASKET PROBABLY ALRIGHT.YOU HAVE TO LOOSEN HEAD BOLTS IN SEQUENCE BACK OFF A LITTLE AT EACH BOLTS.IF HEAD GASKET LOOK DAMAGE AT BOLT HOLES REPLACE HEAD GASKET.
Nov 13, 2009 | Toyota 4Runner Cars & Trucks
Torque specs for 1998 26hp kohler head bolts. aluminum head
I use 150 ft lbs on my racing 2-cycle engines, tighten in a star pattern.
Sep 16, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Yamaha EF3000iSE Generator Logo
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Roland W VanLue
Roland W VanLue
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
