Question about Saeco Coffee Makers & Espresso Machines
Espresso machine not frothing
Water was not flowing out of handle. Took handle apart and reassembled it worked fine for a while then started to jam up again. Took it apart and reassembled a second time. Now flowing ok but no froth
SOURCE: frothing tube
Sheryl,
It sounds like the tube is clogged.  Remove the silver tip on the bottom of the tube.  Hold it up to the light and see if you can see through it.  If you can not, take a tooth pick and clean the tip out.  This seems to have worked for mine.
Adam
Posted on Oct 24, 2007
  • 8 Answers
SOURCE: replacement parts for Braun 3062 espresso machine
Google Braun 3062. They are offering all kinds of parts
Posted on Dec 30, 2007
EsWorld
  • 1618 Answers
SOURCE: frothing valve leaks water when not in use
There are 2 inserts pins in the steamvalve assembly, they need to be replaced replace. Easiest solution order a new valve assembly.
Posted on Feb 27, 2009
SOURCE: milk not frothing
Remove the black plastic outer sleeve of the Frothing Wand (some models have a metal outer sleeve). If done correctly, the “sleeve” has been removed, but the inner wand with red or black washer, is still connected to the machine.
2) The part of the sleeve assembly that you have removed is comprised of 2 pieces, the frothing sleeve and the center piece. The center piece can be seen if you look into the top of the wand.
3) Using a pencil (eraser end), or similar shaped object, push down on the center piece until an audible “click” is heard. The “click” means that the centerpiece is back into the proper position. When in the proper position, the center piece visibly sticks out the bottom of the sleeve about ¼-inch. It looks like a bird beak.
4) Now put the sleeve back on the machine and your machine should be ready to froth again.
As for the milk island, translaltion from the italian solution using google and drying all the parts works
Posted on Apr 30, 2009
MNfisherman
  • 11896 Answers
SOURCE: not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
Posted on May 09, 2009
No water coming down to cups
Assuming that you are certain that there is no scale blocking the brew head and that the pump is running normally, try making a cup with no filter cup installed into the filter handle (obviously with no coffee grounds either) but with the handle installed into the machine
If water now flows, your problem is a blocked filter in the floor of the filter cup, and the easiest and most reliable way to fix that is to purchase a replacement filter cup :o)
Check also that the filter handle's outlet holes are not blocked. The tar like gunk that builds up in the filters and handles can be quite hard to remove
Nov 12, 2013 | Bialetti Mokona Espresso Machine
Recently my Krups 4050 espresso machine starting beeping repeatedly while making espressos. Same thing every time: espresso starts to pour out then machine beeps like something's wrong and doesn't finish...
It needs a new flow meter. I replaced the one in mine and now it works fine. I took the old one apart and the little magnet inside is a ferrite magnet which rusts over time when it comes in contact with water ( duh). If the new one does this I am going to just replace the little magnet with a rare-earth magnet which will cost about $1 or less and shouldn't rust out. I am wondering if the company changed the magnet in the new flow meter so this doesn't happen or if planned obsellesants, just last long enough to get it out of warranty, is the company's motto. The new flow meter was around $30 when the added the $9 for shipping.
May 19, 2010 | Krups Cappuccino/Espresso Maker -...
No water or steam is coming out of the frother. Tried rinsing machine and going back and forth from brew to froth with no results.
Just fixed this same problem by taking apart the water solenoid valve and cleaning out its connection tube of deposits that was blocking water/steam flow. I removed the magnetic coil but that's not required. The connector was very tight because it had loctite sealer on the threads. I used plumbers teflon tape on the threads when reassembling.
May 11, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
Not frothing milk
May 09, 2009 | Krups XP7225 Espresso Machine
No steam when valve opened, spits out water in the beginning of frothing
There is a small teflon piece on the inside of the steam tube, you will have to disassemble the frother to get to it. Remove this piece. Reassemble and the wand should work fine.
May 08, 2009 | Gaggia Syncrony Compact Coffee...
GAGGIA BABY. NO WATER COMING OUT.STEAMER FINE
I had exact same problemeven took entire machine apart - all fine. Solution is very simple... descale with Gaggi descaler solution. Remove filter and block, mix solution with 1.5L of water, turn on for 20 seconds, wait 20 rinse through steamer, wait 3 minutes and repeat until all solution used - rinse compeletly with clean water
Jan 19, 2009 | Gaggia Baby Espresso Machine
Water through frothing wand
It might sound silly but you haven't got the steam valve on the right hand side open have you?
Nov 27, 2008 | Gaggia Evolution Espresso Machine
Steam not frothing properly (very weak output)
It can be the electric magnet valve that has to be replaced.
Aug 07, 2007 | La Pavoni Stove-top Espresso Maker...
Coffee Makers & Espresso Machines Logo
52 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
