Question about Tablets & eReaders
Little scholar tablet's sound is gone, but is on when using headphones.Tried reset, reboot, hard reboot, on-off,plug and unplug headphones,warranty expired, tech support has no answers.Please, help...
  • 400 Answers
SOURCE: sound problems on tablet
It sounds as though the switch on the phone jack is not making connection when the phones are unplugged. You can probably clean it by spraying some contact cleaner in the jack, then plug and unplug the phones several (lots of) times. I've had good success with WD40, but it does leave a residue. If this does not fix the problem, you can open the tablet by gently prying the screen off with thin blade (a knife might work). Work your way around the entire screen until the body separates. Gently open and perhaps you can access the jack switch to clean it, if it is not sealed. I hope this is helpful to you.
Posted on Mar 23, 2014
  • 78 Answers
SOURCE: I have no volume no sound Would a Hard Reset fix this problem?
A hard reset is worth a try but it is unlikely to fix the problem, it sounds like a hardware issue.
Here are instructions for a hard reset
Make sure the tablet is OFF.
Press and hold the Volume Up and Power buttons at the same time.
When the Android starts to flash, release the buttons.
Then try to press different hardware buttons until you are given a list of options.
Note: If Volume Up and Power doesn't work, try Volume Down and Power.
Posted on Dec 25, 2014
michaelghick
  • 142 Answers
SOURCE: How do I get speakers working on 7.85 tablet?
Check the volume control, if the volume is up, then verify that the headphones work OK by testing them on another device.
You may need to power off/power on the device and try again.
Posted on Jan 04, 2015
  • 47 Answers
SOURCE: When I plug the headphones into my Samsung Galaxy 10.1 tablet, the sound comes from both the headphones and the speakers on the tablet, shouldn't the speakers be turned off by the headphones?
As mentioned above, SoundAbout should work.
Posted on Jan 15, 2015
easybill99
  • 996 Answers
SOURCE: I performed a factory reset on my Maxtouuch 7" tablet & now it wont load, I've tried a hard reset but still frozen on the loading screen, please help
reflash with latest files with flashing tool
Posted on Jan 23, 2015
My rca tablet won't turn off help
You don't mention the model or android version, so try a search on the make and model to find the manual, which should mention how to do a hard reset. If not, leave it unplugged, and it will eventually power down. Sounds like it locked up. See if this link helps: How to Hard Reset or Reboot any Android phone or tablet
May 24, 2017 | Tablets & eReaders
Someone please help me reboot my mid m9100 android tablet
If the unit is frozen, it might be easiest to let the battery completely die. Most low end tablets can only be hard reset by taking them apart and unplugging the battery. Once the battery dies you can plug it in and charge it and reboot.
Apr 27, 2015 | Tablets & eReaders
Unlock my Emerson tablet EM744
emerson em744 factory reset instructions July 18, 2014Uncategorized
Emerson em744 factory data reset - southern telecom, Emerson em744 factory data reset if you have set a password on your tablet and forgotten the password, follow the instructions below to reset the tablet.
How to hard reset emerson tablet? - the tablet has a, My girl locked her emerson tablet how do i unlock it.. foegot password emerson 543? would like to hard reset my tablet videocon vt75c. i had tried the options.
Where is the operating manual for emerson tablet mmem 744, How do i hard reset my emerson tablet em744? i had my ereson m744 connected to the pc to charge and when i unplugged it, it was locked. i have not established a. How to reset an lcd tv ' ehow, Navigate to the "factory reset" or similar wording option using the arrow keys on your tv's remote control or on the front panel of the tv. press the "ok" or "enter.
Gsistore.com, (2) 04a42-015b-05 120v 4" bracket only (2) 405-043a 120v 4" blade only (2) 501-138b 120v 4" motor only 02a42-009a lock strike for sm models 02b01-085d door assembly.
How to connect wireless headphones to a pc ' ehow, Test the headphones. pick out a song or a video and play it on your pc. connect your wireless headphones and verify that you can hear the audio..
5 home depot hacks - buzzfeed, 5 home depot hacks. home depot may not have swedish meatballs, but it can be the ultimate store for affordable, durable, modern furniture if you know how to hack it..
Amana top load washer service manual - scribd, This base manual covers new double front panel series, top load wash machines. refer to individual technical sheet for specific information on models..
Stirling engine design manual - scribd, Stirling engine design manual 2nd edition this design manual provides an introduction to the stirling cycle heat engines. it analyzes compares non proprietary engine.
Mar 29, 2015 | Tablets & eReaders
This can be a hardware (bad headphone jack) or a software (rom update) issue. If the tablet is in warranty, try taking it to your dealer and see if they have a fix.
Otherwise, some people have had success doing one of the following:
1. Plug headphones in after starting music. Watch for headphone icon to appear on screen, meaning tablet has recognized that headphones are attached. Make sure plug has been put into socket all the way.
2. Install app SoundAbout on your tablet and see if you can route sound to headphones only.
3. Check Settings/About Device to see if there is a software update for your tablet. Install the update and see if that fixes the problem
Jan 12, 2015 | Samsung Galaxy Tab 101 Tablet...
How to unmute nobis tablet
see if the headphone works 1st if it is then the speaker is the issue.
or that jack you plugged the headphones in is the issue
Jan 04, 2015 | Tablets & eReaders
Dec 25, 2014 | Craig CMP741d Tablet
How to fix Nobis 9" tablet, stays on go screen.
After you have tried a reset (hard & soft) you"ll need to take the back off. once you remove the two screws you can pop off the colored backing. Remove the black tape (don't worry if you put the webcam out)Unplug everything, start at the bottom with the hard drive. Just lift the little black tab & it will come right out. Then then unplug the monitor in the upper right side. now press the reset button hold & press the power button hold 20 seconds. now plug everything back in just side the ribbons back in place & close the black tab. Now close the backing & turn the tablet on it will load to the welcome screen.
Jun 01, 2014 | Tablets & eReaders
Tablet trio android
Had several do this lately
You got to do a hard reset but it might wipe out any apps or other data too. If you can hook it up to ur USB connection and backup ur data first. Try doing the soft reset first..hold the power and sound down keys until it reboots.. if this fails u always got the hard reset..the little hole in back by the card reader..use a toothpick and unplug it from power and computer first..CAUTION u can loose ur settings and be force to update and reinstall any apps if it is set for backup wipe data..
youtube has some good vids on diff resets but if you can access the menu then u got nothing to loose.
Let me know if u get stuck
Chad man
Apr 20, 2013 | Mach Speed Trio DROID-7C Android 2.3...
My Asus Tablet will not turn on
With the tablet turned off, press and hold the volume + button...now press and hold the power button at the same time....you should see a list of options...use the volume + button to scroll options. select recovery mode then push the volume - button, try to "reboot system now", if that doesn't work, you may have to select "wipe data factory reset" but this will wipe all of your apps, and restore the tablet to out of the box condition.
Oct 20, 2012 | ASUS Tablets & eReaders
Fujitsu T series; no sound when I plug in the headphones
I have the same problem and just figured it out. Go to the sound settings and set the earphones as the default. I just did this and it now works.
Nov 27, 2008 | Fujitsu LIFEBOOK T4010 Tablet PC
Tablets & eReaders Logo
179 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
