Question about Sony Televison & Video
How can i connect sony bravia tv to Marantz pm7200 Amp
How to connect the Tv through Amp
  • 4234 Answers
SOURCE: Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
Posted on Jun 11, 2008
MNfisherman
  • 11896 Answers
SOURCE: programming remote to operate Sony Bravia TV
You can find your codes here:
www.tvcodes.com
OR
www.remotecodelist.com
OR
www.remotecontrolsrus.com
Posted on May 10, 2009
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
SOURCE: Cannot remove tv guide banner from Sony bravia 52'
Click on the display button (upper left corner) as a short term fix - it will turn it off immediately - not sure of how to permanently solve this though.
Posted on Nov 07, 2009
Connect the intergrated AVampliphier TA-VE215 to TEAC LEV32A1HD tv dvd combo
Connect from the TV's headphone output to the amp's "TV" inputs (3.5mm stereo to two RCA's). Connect speakers to the amp, and select "TV" at the amp.
http://www.teac.com.au/downloads/product_downloads/LEV32A1HD_User_Manual.pdf
http://www.cashgenerator.co.uk/cmsstatic/w282105.JPG?browse
Oct 28, 2014 | Audio Players & Recorders
Audio out locations on back of tv
Hello
You want to connect your TV with an external audio device, and want to hear sound from it, I assuses, and posts this solution.
There is audio out sockets at the back side of the TV, very near to S-Video socket. Marked audio "L" & "R". These two sockets are audio out socketsfrom TV to connect any external audio amp. Just use an audio cable to connect these sockets, to 'Audio IN' of the amp socket. Switch ON both the devices. You can hear the audio of your TV programmes by the amp you conneccted with.
The picture of the AV cable is given here. Take red and White colourd connections to connect the TV with amp. Left the Yello coloured pins free. It is meant for video. 2_11_2012_3_19_43_pm.jpg
Feb 11, 2012 | Element Electronics FLX3210 32 in. LCD TV
Where is the internal fuse of marantz pm7200
http://www.retrevo.com/support/Marantz-PM7200-manual/id/511bh847/t/2/
http://www.fixya.com/support/t409652-marantz_pm_7200
The top link is for a manual for your model. The second link is a Fixya link concerning "no power". I'm not sure why you are looking for fuse but, have to assume it's a no power issue.
http://livesupport.maybenow.com/Marantz
The above link is a support link for Marantz. Hope this helps.
Mar 10, 2011 | Marantz PM7200 2-Channel Amplifier
Hi, I have a Marantz PM7200 KI Signature, This morning sadly realised that the amp is gone, There is no light on, something like no power. Firstly, I look for the fuse socket but there is no socket on...
hi,
First of all check the power at the socket to which you have connected the amp.If you are not aware of electronics, then do not go for a test with an amp like KI signature.
it will have a fuse in its inside. its only blow off if there is some fault inside the its circuitry. consult someone who is well equipped for the same.
ok
Feb 06, 2011 | Marantz PM7200 2-Channel Amplifier
I want to connect my bravia lcd to my marantz sr770 i can only get two chanel sound from my two front spearker i cant get the surround working
Let's break this into little pieces. Disregarding the TV, does the Marantz otherwise provide multichannel sound?
How is the TV-related audio getting into the Marantz? Analog RCA yields only 2-channel audio.
Two front speakers are only capable of two channel sound.
Jan 24, 2011 | Marantz SR-770
How do i get my tv sound to play using the speakers from my hb405su home cinema instead of using my tv speakers
I assume you have an amp with the speakers. You will need cables connected from tv to surround amp , connect amp output to tv audio input and make sure you select amp for tv feed . then just turn off tv volume so the surround sound takes over.
Pete
Nov 08, 2010 | LG Televison & Video
Marantz pm7200 hdam, will not power up, checked internal fuses all ok, over rid the internal power-on rely and power amp powers up but pre amp circuit still dead, any idea, power panel look fine but...
The preamp stage might be dead. Not much you can do but to bring it in. Make sure the input selector is on the right input.
Sometimes there's a "Monitor input" usually Tape2 input that overrides everything
Sep 01, 2010 | Marantz PM7200 2-Channel Amplifier
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
