Question about RCA Televison & Video
How do I fix this RCA Remote that is stuck in LISTEN?
The remote is stuck in LISTEN with a weird sound. No buttons work. TV and DVD lights flash. I have removed the batteries for over 30 minutes as recommended by Customer Support. It did not work.
fixyadude1
  • 57 Answers
SOURCE: RCA remote
Could it be possible that the remote needs reconfigured? If none of the buttons work, the it could possibly be that you need to re-enter the TV code back into the remote.
Posted on Sep 24, 2008
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
  • 172 Answers
SOURCE: Samsung TV Remote
Replace it with a Universal Remote with Learning, This way, if the new Universal codes in its Manual don't work for your Samsung, (they most likely will if the new remote is not used older one bought off eBay) then you can Teach it to Learn codes off the working keys on you Samsung.
Sony Learning Remotes are a very good choice, sold at Walmart or eBay. The advantage to a good Universal, is you can also program in all your other audio/video remotes into one remote.
Posted on Aug 24, 2009
SOURCE: The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
Posted on Sep 28, 2009
SOURCE: My remote does not work with my bush a632 tv. i
Hi there we had same problem so phoned 08456040105 and they told me to press menu button on tv for 10 secs and take batteries out of remote and press power button on remote for 10 secs while batteries are out. it worked for us doing both at same time....good luck
Asker's Testimonial " Oh my goodness thank you so much for this advice. I was a bit sceptical but it worked wonderfully!! " - aurora393
Posted on Feb 07, 2010
I have 2 remotes to my RCA LED52B45RQ tv. both are RCA remotes and we are having the same problem with both... they randomly stop working (nothing works). power button lights but nothing happens.
You may have a stuck button and not know it. look at the led end of the remote with the camera on your cell phone. If you have a stuck button you will see the led flashing. If it isn't flashing. push a button to see the led flash. Keep pushing different buttons to see if the led will flash without holding a button down. If you push a button and the led doesn't flash, it can be worn carbon button or the ic in the remote is failing If this test procedure does not find why the remotes die. you may want to invest in a a remote that will never become obsolete or worry about codes to operate more devices. It's called a Harmony remote. It's awesome. Logitech Harmony universal home theater remote and app
Sep 13, 2016 | RCA Televison & Video
Programming Universal Remote with RCA Sound System
You don't say whether you tried using the code search function to find something that works. As for the lack of a "sound system" button, you should be able to select any button other than TV to find a code.
Feb 13, 2014 | Sentry Safe Sentry RMC10 Universal Jumbo...
How do you program a universal remote to a model 6420FF Sylvania TV?
Code search. Hold down code search button until on-off light flashes then stays lit. keep pressing the on-off button until the power to your tv goes off, then hit the enter button. your remote should be set to your tv!
Nov 24, 2013 | RCA Universal Remote Control Transmitter...
Can not control the volume on an rca
Ok to reprogram the remote and this only works if you just use the remote for the tv and the receiver. Like i was saying to reprogram the remote hold the tv button till all the top lights flash, then push the red power button, then hit the up arrow button slowly til the tv cuts off, once it cuts off hit the pound (#) button. The top lights should blink three times, that should reprogram the remote, If it is a tv/vcr combo or a tv/dvd combo then there isnt a code for it. Also there is a series of years that the rca tv's wont take a full code and u can just control the power and the tv channel
Sep 05, 2010 | DISH Network IR Remote Control
I have dish network and a new rca tv with dvd the
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Mar 11, 2010 | DISH Network 322 DTV Receiver
Dvd stuck in RCA widescreen tv
There are two things you can try to correct this problem on your TV/DVD combo unit:
  • If you're using the remote control, press the DVD/TV button first to make sure the remote control is in TV mode.
  • If you're trying to use the buttons on the front of the unit, unplug the TV/DVD for two minutes, and then plug it back in. Press the ON/OFF button and try again.
Feb 20, 2010 | RCA L40HD33D 40 in. LCD HDTV
I bought your RCA universal remote that controls 4 devices. The code list does not list my Magnavox DVD/VCR combo (MWD2205). When I went to the website listed on the back of the remote...
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 16, 2008 | RCA Universal Remote Control
RCA RCR311W remote
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Nov 10, 2007 | RCA RCR311B Remote Control
Whats the tv remote code if i have a direct tv + remote.
The Directv remote isn't capable of fully emulating the native remote of the Symphonic Combo. You can get limited functionality though.
1. Move Remote slider to "AV1" position.
2. Hold down mute and select until you get 2 flashes of the green light, then release both keys.
3. Enter 20821 and observe 2 more flashes of the green light.
Next lock the volume controls to this device.
4. If you have moved the remote's slider from the AV1 position, move it back. The slider should remain on AV1.
5. Hold down mute and select until you get 2 flashes then release both keys.
6. Enter 993 and observe 2 flashes.
7. Press and release THE SELECT KEY and observe 2 more flashes.
You can control the TV's power using the big power button under the device selector.
Oct 23, 2007 | Symphonic WF20D4 TV
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
