Question about Tracfone Wireless Alcatel A392G
How do I stop the beeps when dialing and navigating
My fridge freezer wouldn't stop beeping when it swtich on. The model no is FF4DSB hot point quadrio.
When you turn it on if it starts beeping you need to turn it off by holding the freezer off button at the top (or if a dial turn freezer dial to off)
Then turn the freezer back on and it will have reset the control and stops the beeping.
Then just leave it and after about 10-15 mins you should hear it kick in.
Jan 05, 2018 | Refrigerators
I have a dial tone, the operator can speak to me, but I can not dial. I get a three beep noise. The function key and all keys just make a three beep noise. The only keys that do not give the three beeps...
see this pdf file this will guide u sir.............
http://pdf.textfiles.com/manuals/FAXMACHINES/Brother%20IntelliFAX%20770%20Home-Office%20Fax%20Machine.pdf
Jul 17, 2008 | Brother Office Equipment & Supplies
How do I forward calls and then unforward?
Call forwarding is not a feature of the cordless phone, it is done by the telephone company the CS6829 base is connected to. Contact the provider of your telephone service to see if it is available and
have them set you up. For example, with Verizon Cellular Home Phone Service, we have a CS6829 base connected to the Verizon
Service box: to forward incoming calls to another number we just
enter (dial) *72 and the number to be forwarded to and listen for
a 'beep beep beep' confirmation signal, then hangup. To stop the call forwarding we enter (dial) *73 and listen for the 'beep beep beep', then hangup. For your service, the steps may be different !!! Good luck.
Mar 30, 2016 | Vtech CS6829 2 Cordless Digital Answering...
Why does dial tone go beep beep beep?
It is called a stutter dial tone and usually means that you have messages on you voice mail.... But its is sounding like a motor boat, and sounds like your in a tunnel while talking. You may need to call your local repair. Could be a bad line card.. as long as its happening on all your phones..
Aug 15, 2015 | Lands Phones
Why no dial tone only beeps
on my phone it beeps, when there is a answer machine message when you clear that it stops beeping try that.
Sep 02, 2014 | Philips Kala 6523 Cordless Phone
Keeps beeping and displaying approaching turn
The "Approaching Turn" message is coming from an active navigation on your device. To turn it off, press and hold on the left side of the bezel (GPS), then press the lap/reset/quit key to exit the compass screen. You should then be in the GPS menu. There should be an item in this menu titled "Stop XXXX" where XXXX is "Navigating", or "Back to Start", or something like that. Select that option, and it should stop the navigation, and eliminate the "Approaching Turn" messages.
Sep 29, 2013 | Garmin Forerunner 405 Handheld GPS...
How do I stop my Bosch logixx 8 from beeping endlessly at the end of a cycle?
hi, I found out last night after being wokenup by endless beeping.... start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now....
May 09, 2012 | Washing Machines
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
When I pick up the receiver to dial out, it beeps and beeps for about 6 times before I can dial
each beep means a new voice mail...so 6 beeps should indicate that you have 6 new voice messages :D just dial your voice mail and check them and it will stop!!!!! :D
GOOD LUCK AND PLEASE RATE THIS POST!!!!!!!!
Oct 08, 2009 | Uniden Cordless Phone
Stop beeping at end of wash on bosh machine
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops. Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Aug 16, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Tracfone Wireless Alcatel A392G Logo
46 people viewed this question
Top Tracfone Wireless Cell Phones Experts
Dustin
Dustin
David Payne
David Payne
Are you a Tracfone Wireless Cell Phone Expert? Answer questions, earn points and help others
