Need Gas Selector Valve Assembly Part no.YDF06
  • 1,631 Answers
For what heater?
make and model?
Posted on Apr 12, 2015
Fuel Gas Tank Reservoir Selector Valve leaking when using front tank
The seal in the selector valve is bad on the front side.
Replace the valve or rebuild it.
Disconnect the battery ground cable before doing any work around gasoline.
May 01, 2014 | 1988 Ford F 250
1988 ford e150,,fuel tank selector valve.. When i
There was a recall of sorts on the switching valve under the truck. You'll probably need to have it replaced. don-ohio
Sep 13, 2011 | Ford E-150 Cars & Trucks
Fuel filter light comes on when change from rear tank to front tank fuel filter has been change, is there an fuel relay if is where,
I am guessing that your truck is a Diesel. There is no electric fuel pump on the diesel models. The fuel filter light comes on when there is not enough fuel pressure. Possible problems include the selector vavle not fully switching, and/or an obstruction in the pick up in the front tank.
the selector valve is located underneath the truck on the inside of the frame rail on the drivers side If I remember right. Try swtiching to the front tank and tapping the selector valve assembly. If that clears up the light then the selector valve is sticking and needs to be repaired or replaced.
Jul 23, 2011 | 1993 Ford F350
Trying to change my fuel filter on my 2003 FLHRCI
You will need to drop the fuel selector valve on the bottom left side of the fuel tank. There is just a jam nut between the tank and the valve, once this is loose you can drop the selector valve and the fuel screen will pull out the bottom of the tank.
Remember that you will need to drain the tank first, you can do this by supplying vacuum to the little hose that goes to the motor from the back of the valve.
Please be careful when working around gas!
Regards Outback
Apr 25, 2011 | 2003 Harley Davidson FLHRCI Road King...
I have a Rheem RGDA-100A-AR gas furnace, and I believe the pilot light is out and needs to be re-lit, but I'm not sure where it is. Any ideas where it might be or what it might look like? And do I have...
Hello and thanks for inquiring. Take the front covers off the inside unit. This is where you will find the Gas Valve. Next locate the pilot assembly. This can be done by following the thermocouple from the gas valve to the end where you will see a little v shaped piece. This is where the gas will come out. Turn the Gas Valve selector to PILOT. Depress the gas valve and use a match to light the pilot. Hold the valve down for 30 seconds. Then let up and to the gas valve to the ON position. The unit will come on and light and when the bonnet temperature reaches 180 degrees the fan will kick on. Hope this helps you.
Jan 27, 2011 | Heating & Cooling
Dear P. I have YAMAHA VIRAGO 250 and have a problem with the fuel selector. I tried on all the three positions (ON, Reserve and Primary) but in all the choices I run out off fuel without any extra fuel...
To see what is wrong you will have to drain the tank and take off the fuel tank outlet(filter assembly). What you should see is a tube sticking up with a fuel filter over it. The tube allows the fuel to enter the carburetor down to that level , when the fuel petcock is in the ON position. When you switch to RESERVE the rest of the fuel flows down through a hole at the base of the fuel petcock. If the tube is missing from the fuel tank outlet(filter assembly) or/and the actual fuel petcock switch (sometimes a separate part )you will not have RESERVE. Another way you have no RESERVE is if you have a leaking four hole washer in your fuel selector. This allows the fuel to flow from RESERVE to ON inside the selector valve(gas leaking in petcock but not escaping outside petcock). "Honda" has all sizes of 4 hole washers available, but , the assembly may not be designed to be taken apart and reassembled. In either case you may end up having to buy an assembly to fix your problem.
Sep 30, 2010 | Yamaha RD 250 Motorcycles
My indersitt cooker wont stay lit once i have lit the oven with a lighter what do i need to do plz
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat(located inside the top section of the unit)
-- defective selector switch(mounted on the front control, or part of the touch pad assembly)
-- defective gas safety valve(mounted on the valve assembly)
-- defective gas valve coils(mounted on the valve assembly)
Nov 05, 2009 | Kitchen Ranges
Oven will not heat up
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
-- defective thermostat(located inside the top area of the units body structure)
-- defective selector switch(located on the control panel, or part of the integrated control board key pad.)
-- defective gas safety valve(located on the gas valve assembly)
-- defective gas valve coils(located on the gas valve assembly)
-- defective flame sensor(located on the gas valve assembly)
NOTE(If everything checks out ok with the ignitior, and burner/valve assembly, this will lead to a failing control board)
Nov 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont come on, installed new igniter
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
-- defective gas safety valve/coil assembly
Jun 22, 2009 | Whirlpool Ovens
Where is the coil valve located?
The coils on this unit are located on the gas/burner valve Assembly. this is a all in one situation. everything is located on the gas valve assembly. you will need to remove the coils from the gas valve assembly.they are attached to the valve assembly.
Located on the back side of the unit on the lower back side. (right)
May 25, 2009 | Whirlpool GGQ8831L Gas Dryer
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
