Half the screen is black and half is visible. What could be the problem
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 12, 2015
lukster
  • 217 Answers
SOURCE: picture problem, half screen blank
On a plasma there are 2 buffer boards, upper and lower, it all depends which half of the screen is on as to which buffer to replace, the buffer boards are located usually on the left hand side if you have the back off the unit. You maybe able to reseat the ribbon cables and get the video back up
Posted on Feb 17, 2007
SOURCE: LG plasma tv has half black screen
Hi Hi
Posted on Jun 12, 2009
  • 9 Answers
SOURCE: Panasonic TH-42PX60U PLasma - 1/2 screen blacked out
If the screen split is exactly 50/50 top/bottom You are not getting SU or Scan Upper drive.
These are lovely set to work on.
Most likely is SU board itself - Not repairable just to be replaced.
Sorry I work in the UK so I can only guide that the UK part is around £30
SU may have been damaged by failure if the PDP (Plasma Display Panel) but is 9 years only had 2 screens damage the SU board.
There are several setups to do after fitting a PDP. If you don't have the service data - Do not risk it, Reduced life of the Panel and a safety risk.
Posted on Aug 14, 2009
  • 178 Answers
SOURCE: thin horizontal black line appeared lower half of
Fixed non moving lines usually means you have a problem in the panel display or t-con. If it is in warranty get it to a factory authorized service center. If not you can try to change the t-con and see if this fixes the problem, if not then it will be the panel it's self and will be cost prohibitive to repair.
Posted on Sep 01, 2009
  • 49 Answers
SOURCE: top half of screen goes black - sometimes the
you can referen the article:
How to Fix a Black Screen at Startup
maybe it can give your some help
Posted on Mar 05, 2010
My monitor goes half red pin striped and black w/ some visibility
It sounds like you may have connections problem (loose or dirty contacts) between the LCD panel and the logic board, look for that first, worst case will the LCD controller (T-CON) board, which is part of the LCD screen panel assembly. See some pictures here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
http://s807.photobucket.com/home/budm/allalbums
Apr 04, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Screen was going red on the top half of the screen, then..
The Y buffers were going bad, sounds like they went , you should get the Y upper and Y lower also the Y main. be aware the screen may be bad but tou won't know till you try the Y boards,
Jul 23, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Toshiba 35A44
check the verticle stage
electrolitic capacitors
and the verticle IC
Sep 04, 2008 | Toshiba 35A44 35" TV
Emerson HDTV
this is a chip on film problem it can't be fixed if your set is still under warrenty you can have it replaced. The repair site will scrap the unit because the chip is actually embedded in the screen.
Jul 21, 2008 | Emerson EWL20D6 Television
Envision EN 780e Monitor Vertical Problem
u just give reset... the menus must be half visible atleast...
or just see the same type in option in other monitor and just write down how much time u must press navigation and iother buttons to go to reset option & to give reset...
once if u have done wit resetting ur screen will come normal to size then u can adjust height and width....
Feb 03, 2008 | MPC Computers Envision EN 780e (White) 17...
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
