Question about Toys
I found the answer to my question by loring...chien regarding repairing a DC motor 6V at 15000 RPM w/ 2mm shaft, for toys.. Thank you. Now I need to ask - where do I find this motor?
  • 17,115 Answers
How can I replace the motor in an Aerolatte?
The whisk shaft is glued to the motor shaft. I used needle nose pliers to pry whisk shaft away from motor shaft and it separated easily. Ordered D.C. Motor from china on ebay. 21 mm diameter case. 2mm shaft width. Motor was .99 cents freight prepaid from china to USA.
Feb 15, 2016 | Aerolatte Original Steam Free Milk Frother...
Where can I get AEG Adaptor 6v-1a
Anu 6V 1Amp DC adapter can be used. It can be available at most of the electronic spare part selling shops.
Gopakumar Gopalan Google
Nov 14, 2015 | AEG Toys
Model 841.205 lw2019. Where can I buy 13 vdc motor?
13v Dc Motor - Alibaba.com
www.alibaba.com > Mechanical Parts & Fabrication Services > motor
13v Dc Motor, Buy Various High Quality 13v Dc Motor Products from Global 13v Dc Motor Suppliers and 13v Dc Motor Manufacturers at Alibaba.com.
12V DC Motor ' eBay
www.ebay.com/bhp/12v-dc-motor
eBayFind great deals on eBay for 12V DC Motor in Electric Motors with Less Than 0.5 HP. Shop with ... Buy It Now. 209 watching ... Igarashi 12 VDC Motor - 4500 RPM - 12 V - Toy Car and Hobby Motor - High Torque. $6.95. Buy It Now ... Worm Motor. Output Shaft Size 1.5 x 13mm/0.06 x 0.51 (D*L) Shaft Total Length 47mm/1.7.
Ametek Motor ' eBay
www.ebay.com/bhp/ametek-motor
eBayAMETEK MOTOR GENERATOR E56617 72 V DC WINDMILL TURBINE PERMANENT MAGNET WIND. $145.00; Buy It Now ... Ametek/Lamb 116765-13 Vacuum & CentralMotor, NEW 110 volt 3 stage. $114.79. Buy It Now. Free Shipping.
Oct 25, 2015 | Philco Audio Players & Recorders
I need a switchingadaptor for a gemmy lighted tree model MCS-0601000W. Input 100-240VAC - 50/60Hz 0.45A max output: 6v DC 1.0A
Dave, I don't have an answer, but I'm in the same positions as you. My adaptor just died yesterday too. I'm having no luck so far finding a solution. Please pass along any good ideas if you get any. Thanks! Chuck
Dec 18, 2012 | Toys
1988 Playskool Expres Train engine won't run. Light comes on but wheels won't turn. How can I repair it?
i recently restored a playskool express train that my son had, now for my grandson.
The on-off push switch is the yellow button in the smookestack also controlled by the yellow tab on the bottom (the on-off track can stop the train with the tab). If the light is on then perhaps the forward reverse switch (the yellow bar behind the cab needs to be pushed forward or backwards. In the middle might be off. I had to replace the motor, its a common sized DC motor 6V at 15000 RPM w/ 2mm shaft, for toys..
The bigger problem I had was that the battery cover was very finicky in how tight you closed it, and the rubber traction bands for the driving wheels were rotten. I replaced them with 1-5/16" ID x 1/8" O-rings. Still slips a little.
Dec 10, 2011 | Playskool Toys
Treadmill stuck in incline position -- wont' lower
Dear Sir:
I see what is your problem:
May existen 2 problem: a) Mechanical b) Electrical.
a) Mechanical: To due the shaft of Motor Lift bent, this cause to Stuch the motor, and produce some trigger of the breaker.Inspeccion it the shaft is o.k or is Bent.Change or Repair.
b) Electrical:
1) The breaker in the Board Controller can be dirty, or faulty, replace or repair. You can clean with special spray for contact.or use Ethylic Alcohol.
2) Check the rely or contactor for Motor DC, the contact will be dirty , clean and adjust it and replace or repair.
3) Check the continuity wire with VOM ( Range r x 100 from the Board control until the terminal of the Motor Lift DC is o.k or faulty, repair.
4) MEASURE the Voltage DC, with a VOM (VOLTIMETER) in range DC, approximately 48-50DC, if you can measure the same, the Motor is Faulty. You can Replace or REPAIR.
Thank you by this opportunity, best regard.
Sincerely.
E.CUADRA
Sep 05, 2011 | Epic 425 Mx Treadmill EPTL88105 !
I'm looking for a detailed schematic on 3XA78 gear motor. I need the proper ratios from centre to end
Nom. F/L rpm = 180
Full-Load Torque (in.-lbs.) = 27
Overhung Load (lbs.) = 175
Input HP = 1/8
Full-Load Amps @ 90VDC = 1.28
Gear Ratio = 10:1
Mar 30, 2010 | Dayton Dc Parallel Shaft Tenv Permanent...
Ignition Coil for Honda 125 CM /84
The 12v coil on a 6v system will only give a weak spark at best. The coil in the photo should work very well assuming the wires are long enough. Any 6v twin coil should work. If you fit another coil and the bike has spark but will not start, swap the wires at the points. Don't purchase a condenser unless the old one has gone bad. If needed, get a 6v condenser matching the old one.
A “very helpful” rating for this answer? Thanks from Dallas Texas!
Jun 16, 2009 | 2000 Honda CM 125 C
Toys Logo
53 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
