Question about Yamaha PSR-E323 Keyboard
Amplifier ic ba5417 bust i replace new but no sound when i place key
    Top Expert:
  • Yamaha Master
  • 74,198 Answers
Check its wiring according to the wiring diagram. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 11, 2015
Everything comes on lights can see the music is playing no sound
a fuse gone to the speaker terminal of the end amplifier.
There are four lots steering and power transistors or only an integrated powerpack ic to find possible IC in one or in 2 pieces .... can be defective. final stage amplifier is almost always to find on a large heatsink or the cabinet with transistors, or MOSFETs or a one large STK ic they are almost always short-circuited if defect and it is easy to find if defective with a multimeter as it are conventional vintage simple NPN and PNP transistors, it may be that if you have a multimeter ohm sets and measurement performed no resistance is given on the three legs ie the shorted than you the transistors mosfets or sometimes replace an IC output stage 1 or 2 pieces, but do not forget or bad bulging capacitors are responsible or that there was an overload or shorting a speaker cable that has become trapped in the door or a cabinet.
Much options to suggest in case of no sound or only loose connection by shifting a carpet
Mar 23, 2016 | Music
Why does amplifier sound die after a short period of use?
There is a heat sensor on the heatsink (to cooling IC / transistor) which decides current / voltage, in case of overheating. This is indeed to secure IC / transistor power of destruction.
The cause of the excessive heat, the impedance mismatch between the amp to the speakers. It is also possible that parts already exist within the amplifier that is almost / half broken, for example, changing the resistor value, electrolytic capacitors are bulging or dried, isolation transformer windings were charred, solder joint cracking etc. Should be checked, before the fatal damage.
Heatsink on the amplifier (the picture is owned Connelectronic):
Sep 05, 2015 | Laney Music
How to replace roland xp 50 keys And also repair outputs
Disassembly the unit.
Your question is less detailed. If the keys is broken,replace with new.
If you mean "How to",then you need the service manual.
Outputs problem,usually causes by output IC (or input IC) is defects.
It also can cause by AD/DA IC is error.
Mar 15, 2015 | Roland Music
I had Mackie th15a 110vac and it had busted fuse, when i replace it when a new one it got busted again...i plug the power cable to 110vac without a regulator. what would be the possible problem in the...
If fuses keep blowing there clearly is something wrong with the power amplifier. You can start by getting access to it and doing a visual inspection for signs of overheating or short circuits but then it will be necesary to check parts and eventually you will be able to isolate the defective part(s) and repair it.
Dec 26, 2013 | Mackie HD1801 Powered Subwoofer (1600...
It lights up but there's no sound what so ever... /Nicke
Hi, when ever an amplifier comes on and no sound with it,it means that you will need to replace the sound IC that controls the sound that comes out from the output.
When you replace it the amplifier will be fine.
Have a nice day.
Feb 22, 2011 | Laney GH50L 50 Watt All Tube Guitar Head
I have a MG100HDFX head. the output ic was bad. I replaced it still no sound. Any ideas ?
Does anything come out of headphones when you plug them in? If not, you have power supply problems as well...
Nov 03, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Dear experts, i have a MG100HDFX and no sound seems to come out. i replaced the burnt fuse inside the head and i disconnected the timer for the cooling fan cuz thats what kept blowing the fuse. With the...
The problem is not likely to be the fan. I would suspect the output section of the amp to have a problem. These units use a 15 leg power IC for the output. Look for a small IC attached to the heatsink. It will be marked TDA7293V. This is the likely defective part.
Dan
Jan 07, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Yamaha psr-240 lights up but no sound.. no sound from head phones either. Seems to be working with exception of sound out..
try placing your ear on the speakers, adjust the volume control up and down several times, you should hear a humming sound that goes up and down. if not problem with the stage before the amplifier, that is the sound processor. if you dont hear the hum. problem with the amplifier and speakers, including the sound ports or jack. dissassemble the unit. look for loose connections from speakers to amplifier.
Jul 14, 2009 | Yamaha Portable Keyboard with 61...
Line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Jul 04, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Yamaha PSR-E323 Keyboard Logo
115 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
