Question about Caltric Kawasaki 750 Js750 Sx Sxi Pro 1992-2002 Jetski Starter And Drive
What the white fluid come out under engine when start smell like petrol
  • 3,218 Answers
Most likely gasoline. Sounds as if you have a fuel leak
Posted on Apr 11, 2015
Testimonial: "Ok but wear could been leaking from"
  • paulmacintyre
    paulmacintyre Apr 11, 2015
    The supply line from the fuel tank,fuel injector,fuel filter,return line. You will have to get under the car and try to isolate the source of the leak
Was driving my kia sephia it made a loud popping noise with white smoke under hood now it wont start
This could be various issues. Assuming you have not looked under the hood and found anything obvious, I would suggest a tow truck and a good repair shop. Here's a couple tips. If you smell an accrid oder it could be a short in the wiring. If it looks like white steam it could be simple as a blown radiator hose. Quite honestly there's not a good way to diagnose the issue without inspection or more information.
Sep 22, 2015 | Kia Sephia Cars & Trucks
White smoke from exhaust after changing fuilds
Is it condensation or actual smoke? White smoke is associated with diesel mixed in petrol and with quite strong smells. I suspect that it is condensation as water vapor is a by product of combustion and the motor/exhaust will have to warm up to clear it. Check for water droplets at the end of the exhaust to confirm condensation. Burning oil will cause a blueish smoke to emit from exhausts.
Apr 02, 2014 | 2007 Harley Davidson FLHX Street Glide
Smoking from under hood
A leak of some fluid, probably oil, dripping onto the exhaust. This smells terrible, and it only needs a drop or two.
Jan 22, 2014 | Honda Cars & Trucks
Isuzu rodeo gas smell
check the cutoff soleniod on top of gas converter incoming side cos the engine starts on petrol ive got the same truck colin down under
Nov 24, 2012 | 2001 Isuzu Rodeo
Emission workshop warning
if you put some red x in the car it should clear it you can buy it from any petrol station
Jun 06, 2012 | 2001 Volkswagen Passat
Engine will not tick over and srong smell of petrol
LOOK UNDER THE HOOD AROUND THE ENGINE FUEL LINES LEADING TO FUEL RAILS FOR PETROL LEAKS AND LOOK UNDER CAR AROUND FUEL TANK AREA.LOOK FOR LEAKS AT FUEL LINES.REASON VECHICLE NOT STARTING FUEL LEAK TAKING AWAY FUEL PRESSURE.FUEL LEAK HAVE TO BE AT THE FUEL PUMP FUEL LINES OR YOUR FUEL INJECTORS OR FUEL RAIL HAS A FUEL LEAKS AT THE O - RINGS.
Aug 27, 2011 | Ford Fiesta Cars & Trucks
I have a 99 grand am 2 door 3.4l v6 and it is eating a lot of coolant, i was just wondering if anyone could tell me why
that series engine has a lot of problems with the water pump and water pump gasket. check for fluid leaking under neath the engine on the passenger side. its not a bad fix to do it yourself
Feb 12, 2011 | 1999 Pontiac Grand Am GT
Whenever I start the car it smokes than after warming up it stops smoking.
The key is how much smoke? Does the smoke have a smell to it. Are you consuming any fluids, like coolant, or oil?
Tons White smoke that is sweet smelling is usually coolant getting into the combustion chamber.
Less white smoke, especially if other cars are doing it, is normal. For every gallon of gas that you burn, you generate a gallon (GALLON) of water. so this water usually evaporates, but sometimes not. It has little or no smell.
If the smoke is bluish white, that is oil, but usually your converter would fill with oil, and cause error codes, or loss of power. This smell is distinct, but not necessarily sweet.... After the converter heats up, it may be able to burn off the oil and the smoke stops.
What are you consuming, fluid wise, will direct where you go next.
Jan 27, 2011 | 1995 Lexus LS 400
Brand new Husqvarna R53SV 53cm Petrol Mower wont start. We put petrol and oil in it. Connected the spark plug put the choke to on, Pulled the starter string. Nothing happend. After trying a few times you...
Buy some starting fluid and spray some in the carb or air cleaner intake port, if the machine is flooding do not choke while using the starting fluid, make sure you do not have too much oil in the mowwer.
Jul 15, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
2000 Focus Zetec-rough idle, very rough under load.
you haven't said if its petrol or diesel so i'm assuming its petrol since your smelling sulfur sounds if you have a misfire causes could be plugs,leads or ign coil i suspect its ign coil these are common to go.
Mar 25, 2009 | 2000 Ford Focus
Caltric Kawasaki 750 Js750 Sx Sxi Pro 1992-2002 Jetski Starter And Drive Logo
347 people viewed this question
Top Caltric Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Caltric Boating Expert? Answer questions, earn points and help others
