Tv takes about 5min to turn on and has no sound.
Once on tv takes several seconds to respond to remote with fresh batteries
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 12, 2015
Went to settings and accidently turned off blue tooth wi fi now my fire stic remote will not respond air won'' scroll up or down and I can't get back to settings
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
Apr 03, 2015 | Amazon Fire TV Stick
Unit will not turn back on after a power failure
hello.......Robert..unplug the unit..take out the batteries ...wait bout 5min ..put everything back together....see me on amazon bookbundler..bose remote R5
Jan 24, 2014 | Bose Solo TV sound system - Black
TV isn't responding to the remote
Hello, sorry to hear that you having issues with your remote or TV.
First, comes the most common questions but its worth a shot, Did you replace the batteries?
Second, You could try and clean the infrared eye on the tv with a moist cloth to make sure the window on it is not dirty or blocked from the line of sight of the remote.
Also check you batteries once more, also take the batteries out of the remote and push on the buttons as one ore more could be stuck causing the remote to malfunction.
Worse cases are bad remote or bad control board in the TV witch cause it not to respond to the remote. First check the remote very well. You could also replace the remote at www.remotes.com or purchase a universal remote as well.
Only if the new remotes do not work you would call it a bad control board in the tv witch could cost around $90 to replace if there are part available.
Most cases would be the remotes batteries or connectors itself or batteries incorrectly installed.
Thanks for using Fixya.com
Regards
Rulds2008
Jun 14, 2011 | Sylvania 6419TD 19" TV
Remote not responding
It sounds like the remote may need to be reprogrammed to thetelevision or receiver depending on what specifically is not responding. Thefirst thing to do when having problems with a remote it to replace thebatteries, as that is a common cause. If the remote is not changing your DISHchannels then you would need to address the remote to the receiver. This can bedone by pressing 'System Info' button on the receiver then press the 'SAT'button on the remote once, then press the 'Record' button. If the remote is notturning on the television or working the volume, you would need to address theremote to the television. This can be done by doing a 'power scan'. First holddown the TV button for 6 seconds, press and release the power button, then pressand release the 'channel up' button once per second until the television turnsitself off. Lastly, press the pound button, this will lock in the code for yourTV and the remote should then work.
Jul 19, 2010 | DISH Network IR Remote Control
Need codes for LG tv from rca remote thank u.
Hi! You can try using these steps for you to program your RCA remote control to your LG TV.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the device does not respond, repeat steps 1-6.
I hope this works for you.
Jul 13, 2010 | RCA Universal Remote Control
Cant program my rca remote for my LG tv don't have code
Hi! You try using these steps for you to program your remote control to your TV.
I hope this helps.
I have a 32 in insignia and a universal remote was used to try and turn channel..it turned the channel once and now its frozen on that channel even the tv remote wont work and the manual buttons on the tv...
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Mar 24, 2010 | Insignia NS-LTDVD19-09 LCD TV
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Unlock my remote
First of all have you checked the remote with fresh batteries in.
Check there`s no obstruction between remote and tv.
I can get the codes for a universal remote 01 or 02
try those on your sharp remote.
Another way
If you don`t have codes,I can tell you how to find the code on your remote without pressing any numbers!
Hold the code search button until the red light on the remote remains on. Then, press "TV". After this, point the
remote at your television and press the power or on/off button over and over again SLOWLY (one time every second) until
the TV turns off. DO NOT PRESS THE POWER BUTTON AFTER THE TV TURNS OFF!!! Once it does, press the "enter" button on the remote. Then, the remote should work on the TV.
Hope i`v helped!
Dec 02, 2009 | Televison & Video
RCA Universal Remote Code For A Trinitron Xbr Tv
There are several RCA universal remote models. With out your specific model # I can only give you the most common code. 002.
You can also try the steps below to use the internal code search mode if your remote has this feature.
  1. Manually turn ON your device (TV, VCR, Cable Box)
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Oct 23, 2009 | RCA Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
