Question about Welding Tools
How do i flash my machine?machine a
Machine generator makes 110 volts, welder makes no welding current. Will flashing it help?
  • 52 Answers
Flashing won't help if it is already creating 110v. Since you did not specify what model, it's hard to say. Does your machine have three brushes or just two. If two, then it could be stator, rectifier, range switch, ect. If three, start to see if you are getting voltage to the brushes. The middle brush is common to the other two.
Posted on May 05, 2015
SOURCE: power mig astro power 110 burns wire off at tip
I have the same welder. Worked well for 15 years until the drive bearing stopped spinning. I cleaned and oiled the bearing and it has been working like a coon on the farm since. Nice 120 volt welder....
Posted on Jun 07, 2009
KingDWS
  • 1606 Answers
SOURCE: I have a Lincoln wire feed SP-200 welder and my
Try replacing the circuit breaker. They can/do get weak and tend to trip before they actually reach the rated limit.
Posted on Aug 31, 2009
97F350diesel
  • 1326 Answers
SOURCE: My lincoln welder lost its heat penetration
It only produces 100amps. You can only weld thinner metal 3/16" comfortably. Any thicker will resuld in less/no penetration.
Posted on Sep 22, 2009
  • 81 Answers
SOURCE: i have a century powermate 70 mig welder and using
Check that your ground clamp connection to the weldment is secure (tight).
you can weld with the shielding gas, or without.
by not welding right, what exactly do you mean?
Posted on Jul 01, 2010
emissionwiz
  • 78289 Answers
SOURCE: I recently purchaased a Chicago
Here are the specs for the welder from the maker of the unit which is Chicago Electric, this is a line of tools owned by Harbor Freight Tools. Here are the specs:
This is the ideal starter welder! Comes set up for Flux Core Arc Welding (FCAW) for hassle-free operation at the start. Add gas components for full MIG welding with shielding gas later on. As you can see it is designed to run on 240 volts AC
Input Voltage: 240 volts AC, 24.5 amps, single phase, 60 Hz Rated output current: 30 to 160 amps Rated output voltage: 18 volts @ 110 amps Max open circuit voltage: 19-30 volts Duty cycle: 15% @ 110 amps Wire capacity: 0.023" to 0.030"& 0.035" Wire feed rate: 192 to 306 inches per minute Weldable materials: Mild steel, low alloy steel, and stainless steel (not suitable for aluminum) Material thickness: MIG: 22 gauge (1/4" thick), FCAW: 22 gauge (5/16" thick) Includes: 2 lb. spool of flux-cored wire, two spare contact tips (0.023"/0.035"), handheld face shield, chipping hammer with wire brush, multi-purpose wrench
Posted on Aug 17, 2011
I can turn the welder on and it can run all day but when I start welding with in a minute the overheat light will come on and it will stop feading wire. I'm trying to weld on mid temperature.
Have you checked so see if your power cable is the right size?? Is it a 220 or 110? If it is 110 then it will cut off after it gets hot, if it is 220 and the power cord is too small then the machine will be trying to pull more amps than the cord can handle causing it to overheat and shut off.. My husband has been a welder for 20 years.. I'm just passing along what he suggested might be the problem.. Hope this helps!
Oct 03, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
Miller trailblazer 302 it has 110 volts but no 220 volts
Both sets of the 120? If both of those are there (all 4 outlets), then the machine is producing 220v. So get a flashlight and look into the holes on the 220 receptacle, or check the wires on the backside of the receptacle. All that 220 is, is two 120 volts out of phase.
Feb 19, 2015 | Miller Trailblazer 302 Welder Generator...
Lincoln classic 3 d welder
The Lincoln Classic 3D welder has a flashing diode attached between the main generator brushes, this is a cathode to stud diode which also has an NC MOV connected across the circuit for protection from field collapse, it is attached to a copper band and is easily seen, remove the generator cover, standing in front of the welder with the cover removed, it should be on the right side.
This is a common problem on this machine, and is simple to test & replace.
also,... attached to the back of the front control panel of the machine is a 20 amp glassine fuse, next to a 40 amp 800 volt bridge rectifier, both also easily tested and replaced.
check the conduction zone on the exciter brushes, the surface of the brush riding on the slip rings, or commutator, depending on which machine you have, should be 'shiny" and smooth, indicating and insuring proper conduction.
Apr 14, 2014 | Lincoln Electrical Supplies
"I was welding with a
Your generator is a welder?? Yikes, the 220 volts coming out of the genny is not the same as the 220 volts running a welder, it is, but it isn't, the 220 volts used to run the welder are transformed into DC, in the 50 -150 amp range, the 220 volts coming out of your genny is 220 volts, AC, at 30-40-50 amps. Now exactly how were you welding with 220 volts AC? Remove anything plugged into the genny, check the oil, check the gas, make sure it is fresh, check the breakers, check the fuses, get it running, now don't try to weld with it again. Unless you have a big welder to plug into it and I wouldn't even do that because of the generator spikes. I might be wrong, but I have never seen a genny with a welder on it for home use.
Feb 06, 2011 | Coleman Powermate Powermate 5000W...
Welding fine , then machine quit welding, would still rev up, but barely arch!
I had the same problem except it was with a miller welder. it was a bad ground connection on the ground cable. if you have an ohm meter. turn off your machine,but do not unplug it. check for resistance from chassis ground on machine to input ground if your input on the machine is good you may have a bad cable,input connection or the ground clamp may not be making a good connection to the cable. good luck!
Dec 21, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
I have a maxstar 150 tig welder that i take with me in our race car trailer, the trailer has a 6.5KW onan NHE generator in it, the welder fails to turn on with this generator, i checked volatge and freq...
Here is the spec sheet for your welder. The only problem that I can see is maybe your power cord is too small. As you can see on the spec chart, the minimum the machine will draw at 115 volts is close to 20 amps. Now your have to multiply that by 1.5 for transformer surge. So now you are looking at 30 amps, which means you will need size 10 gauge wires in your extension cord. If you are going to do some heavier welding, you may even need to go to a #8 cables. What happens also, when you try to draw a lot of current, the generator will bog down, thus providing less power. It would be better if you could use 230 volts. https://www.millerwelds.com/pdf/spec_sheets/DC27-1.pdf
Oct 23, 2017 | Miller Welding Tools
Ranger welder does not generate enough dc current to weld with and only enough current to turn a ac drill very slowly. checked wires seem to be ok.
clean the brush rings with a very fine emery cloth is still then there is a controller board issue at that point it will have to go to a service center do to there are no supplier's for them other that Lincoln go to their sit HERE and find a service center in your area these boards range from $250.00 to $600.00 there is 4 of them in the machine they will have to remove the top and swap the boards till they find the right one have the same welder i have been through this with Lincoln already hope this helps
Aug 09, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Wire speed or heat problems
can you adjust your voltage settings? you may be welding on material that is thicker than what your machine is designed for. your ground clamp may be loose or dirty.
it should sound more like bacon frying than popcorn.
Apr 11, 2010 | Clarke Power Products Clarke 130EN...
Welder not welding
The contact tip is the main source of power, if the tip is bigger than the wire then you will not get a proper conection, the earth clamp is a essential part of the system make sure you have a good earth and all the conections are tight
Jan 14, 2009 | Clarke Power Products Clarke 130EN Mig 110...
Welding Tools Logo
283 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
