Question about Philips Magnavox 51MP392H Rear Projection Television
Blury picture, convergance problem
I HAVE A PHILIPS MAGNAVOX 50" MODEL # 9P5034C103. THE PICTURE IS BLURY, WHEN WATCHING A MOVIE THAT IS WIDE SCREEN THERE ARE WHITE GHOST LIKE AREAS ON THE BLCK PART ON THE SCREEN. WHEN TRYING TO DO THE CONVERGENCE ADJUSTMENT YOU CANT HARDLY SEE ANY DEFINITION ON THE CROSSES TO ADJUST THEM PROPERLY ESPECIALLY THE BLUE. PLEASE HELP! I CANT AFFORD TO REPLACE THE TV RIGHT NOW.
  • 934 Answers
What you're describing is probably contaminated coolant in the crts. Between the outer part of the crt and the lens is a chamber filled with a coolant (ethyl-glycol) which can become contaminated and cause blurred picture. I'd strongly recommend taking this to a shop the procedure for changing these is a bit beyond the layman level.
Remove Crt assembly. Mark the Crt lens position for accurate reasssembly.
Mark the centering ring's postions to make easier realignment and carefully remove lens assembly by removing the four torx screws. Keep Crt assembly vertical so you won't leak the fluid...
Remove the inner lens by carefully prying up on the edge of it.
Dump out the fluid in the sink and wash the face of the Crt and chamber with water to remove all the fungus and crud. Flush the chamber with isopropyl alcohol to kill all the fungus and dry thoroughly.
Reassemble inner lens and outer lens and tighten all four torx screws.
Remove side filler plug and fill chamber with approved new Crt coolant, reinstall and converge.
Repeat this procedure for the other two Crts. It will need this done whether it looks clear or not !! The green and blue Crts in this unit are prone to this failure.
Hope this helps
Bill
Posted on Nov 14, 2007
I also have a PHILIPS MAGNAVOX 50" MODEL # 9P5034C103. and The Picture was getting small and big and eventually the picture doesn't come on any more. I use to come but it doesn't any more
Posted on Dec 19, 2007
The picture is blury
The convergence is dead,need a convergece kit,U know how to solder right?Tries these websites.for the kit.Tv Repair World.com, Shopjimmy.com,Ebay.com or Partstore.com.
Sep 08, 2009 | Sony KP-53HS30 53" Rear Projection...
Double lettering on red when in 1080i good picture in 480p
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Philips 55PP9401 55" Rear Projection...
No picture
Hi, common problem, have a tech replace IC7412, gl, video-tek
Jul 03, 2009 | Philips 9P5034C 50" Rear Projection...
The pitcher is blury and need to be ajusted , how do i do that
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox Television Issue
yes the convergence Ics are bad you will need to replace both convergence ICs they are STK392-120 and you will also need four 6.8 ohm 1watt resistors. You can get the replacement parts at the following link with free installation instructions with pictures.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Television picture
Is it bouncing in and out or just blury? If its bouncing in and out you can get a repair kit on www.magnavoxhelp.com. If its blury my guess is that the convergence IC's STK-392-120 are bad.
Aug 04, 2008 | Philips 60PP9202 60" Rear Projection...
Philips rear projection color and pic problems
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Mar 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
335 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
