Why am I able to pick up most fm stations but one I know I should be able to pick up either goes silent (no fuzz or anything)sometimes it comes in very fuzzy.7" touch screen ouku buttons on the sides
    Top Expert:
  • 42,022 Answers
Fm stations work on line of sight principle (straight waves that do not bend over the train) so if there is hill or mountain between where you are then it will not be clear reception
Posted on Apr 12, 2015
2 Suggested Answers
  • 3 Answers
SOURCE: How do I get back from fm to main screen?
press the menu button, the fm will stop when you switch modes(like pay an mp3) or when you switch the unit off(press on hold the power button.
Posted on Mar 30, 2008
My bewalt radio picks up fm stations then will cut out or want pick up at all
That is a classic symptom of a weak boradcast signal, signal strength varies with location and atmospheric conditions, that is why you can sometimes pick the stations up and other times you can't. If you don't have an external antenna try and hook one up to boost the signal strength.
Mar 27, 2017 | Audio Players & Recorders
How do i tune Mazda Demio (2004 model) radio to Southern African frequencies?
fm frequencies are just that fm frequencies ( not japanese, chinese ,english or anything else
it is a range of frequencies in the fm band that local stations broadcast on
so all you have to do is to turn the tuner knob until you get 107 fm
so as you turn the knob you will loose 89 and it will go probably 90.5 , 100.20, 102.7 etc and if there is a station broadcasting that your radio will pick up it will come in and then fade out as you keep moving the knob
you may have to change the mode as there are fm 1 ,fm 2,fm 3 bands to get your fm 107 as it will depend on what megahertz 107 is operating on
Oct 05, 2015 | Mazda Cars & Trucks
How do I fix the factory radio-antenna situation where I have no AM radio, when FM works fine?
If you pick up FM. It isn't the antenna. It's an internal radio problem.
Aug 11, 2015 | Cars & Trucks
Hi, I have a GPX Model TVP5 port. tv/am/fm combination. Radio plays, TV has no picture; has 10 "C" Batteries.It's portable. TV won't play. Why? what do I need to do?
Most everything is digital now. There are very few analog OTA stations left. If you do not have a analog station nearby then the t.v. will not pick anything up.
Jan 13, 2015 | GPX Televison & Video
My ICF-SW7600 has a clipping sound when first
It's hard to describe a sound in words, so I'm not sure I know what your "clipping sound" sounds like. You may be describing what's called "motorboating", which is a loud rapid putt-putting that drowns out the desired sound until it fades away. This is usually due to power supply problems, most often caused by bad filter capacitors. If I remember this model correctly, it doesn't have a built-in supply so you need to run it with an external adapter. That may be the source of your trouble. Try a different adapter or use battery power to see if the problem goes away.
If this problem only shows up when you're tuned to the station on 93.9, your radio may be picking up some kind of interference. It's also possible (but very unlikely) that the radio itself is producing a "birdie", which is a false signal on some frequency. If this is the case, it's a very obscure problem that may be very hard to find.
Sorry I can't be more precise, but maybe this will get you started. Thanks for using Fixya!
Mar 27, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
What is the FM radio frequency to use the Hannah Montana Wireless Microphone?
FM 99.7 works best.... However if you have a local FM station using that freq your out of luck UNLESS your handy with a Jewelers screwdriver. Calling tech support will get you a "sorry" but there is nothing we can do. So if you are one of the unlucky ones with a Local 99.7 FM station here is what you can do.
1) Find a dead spot on the FM radio band either at the very low end or high end of the range. You should hear just fuzz (white noise) on your radio. However, on many newer FM tuners if there is no station broadcast there is nothing but silence.
2) Put batteries in the microphone.
3) Get a really really tiny flat head (Jewelers)screwdriver just like the kind in those eye glass kits they sell at the grocery store.
4) Sit right in front of the radio
5) Insert the screwdriver into the tiny hole in the microphone and tune the microphone until the radio goes quiet (no fuzz sound). Or.... you can keep pressing S to hear a beat and the beat is acutally heard through the speakers.
The hole is located just to the left of the screw that you undid to get at the battery compartment, but it's off center. Inside this hole is a small tuning screw. Slowly, slowly, SLOWLY turn the screw driver until you here a change or interruption in the fuzz sound on the radio speakers. This will indicate you found a compatible frequency. Then even slower - tune back to that "notch" until you hear nothing but silence on the radio. Test it by pressing the applause button "A" or by pressing the mic "M" button and talking.
There are multiple places on the FM dial that will "work" as you tune the little screw but you should have already manually selected where (the FM freq) you want to use your mic.
Once it's working it ain't perfect. I doubt you'd do a serious performance on it, but the kids love it.
The mic quality is not top notch for sure.
Fine tune as necessary....
Kelly
Mar 12, 2010 | Licensed Disney Hannah Montana Wireless...
Can't pick up any stations
Some Grundig models have a history of poor front end design where just a bit of static electricity will wipe out tuning. Serious flaw.
Aug 10, 2009 | Grundig YB 400PE AM/FM/SW Radio
Degen DE1103 background tone
the background tone is due to frequency static...the design of the stereo is not good... it lack of noise destortion cirquit..and almost all stereo that is analog usually poor in in design..change the stereo.try stereo that is digital in design..
Oct 13, 2008 | Kaito KA1103 SW/FM/AM Radio
Pioneer DEH 1900 MP receiver - cannot pick up AM stations
normally the problem you are describing means that your antenna is bad. typically, if you have no am good fm bad antenna if you had good am and no fm the fm section of your radio would be bad.
you can test this but you will need an antenna (this can be purchased at most car parts stores for about $10.00) pull out the radio unplug the black round plug from the back of the radio and plug in the new one ( the antenna plug is a universal fit) you will probably need to ground the base of the antenna for the test then turn your radio I'm sure this will fix your problem but if not you can e-mail me at merle840@aol.com
good luck'
Merle
Sep 29, 2008 | Car Audio & Video
 Grubhead
Grubhead
