Question about La Crosse Radio Controlled Atomic Clock
My La Crosse Radio Controller clock will not set itself. I have tried setting the time manually but it always advances by approximately 1/2 hour after the manual set. Why?
    Welcome Back:
    Visited the website for 2 consecutive days.
I have the same problem with my 16" analog La Crosse wall clock - it was adding 30 minutes to the time every time I set it manually because, even in manual mode, it will continue to search for the signal. Mine is the WT-3161BL with blue dial. This series of clock, which are still being sold with a black and a white dial, have only mediocre reviews on Amazon. Users report they are unreliable or reliable for only a couple of years before they become incapable of keeping time. Others have received their radio-controlled clocks - as I did - with the hands disconnected (because they're flimsy). They are very nice looking (with a stainless bezel) but quality control, not failure to understand the directions, is the greater issue.
I am responding to this post even though it is old because these clocks are still being sold - and not cheaply, in most cases, either. It would be nice if someone could PUBLISH the La Crosse instructions for re-calibrating these clocks. Why? Because from my own attempts to repair this clock I think the issue is that the hands, especially if they become misaligned or fall off in shipping and are subsequently reattached, are not in sync with what the circuit board is configured to "understand" as the 12, 4, and 8 o'clock positions. What this means is that when you select your time zone it may not, in fact, advance to one of the above-indicated times and await the signal. It may advance in a seemingly random fashion. It's not random rather the hands are not aligned with what the circuitry expects to be the 12, 4 and 8 o'clock position. If this is the case no matter what time zone you select or how good your radio reception it will never "catch" the correct time.
I have seen references in some of the Amazon reviews for those who obtained warranty service that La Crosse Technologies "calibrates" it and then sends it back. If I had to guess, calibration of a radio-controlled (analog!) clock involves aligning the hands to the position the circuitry "expects" to be the default (factory) preset. If that is correct, pushing the Time Zone button will allow it to advance the correct number of revolutions. If the hands are not in the factory defaults due to shipping damage or a defect with the assembly, it will continue to set itself incorrectly.
What is frustrating about La Crosse Technology radio control analog clock design is that "Manual Set" continues, nonetheless, to engage the atomic time signal. So even if you compensate by setting the time manually it will, as it states in the user manual, continue to "search". When it thinks it receives a signal it will reset the time, if only partially. This accounts for why, when the radio signal is not strong enough, that these clocks cannot seem to "keep time". It also accounts for why, when they are assembled incorrectly or otherwise damaged (or repaired by re-attaching the hands) that it still cannot keep time.
If La Crosse would simply design their analog wall clocks so that Manual Set DOES NOT continue to search for the atomic time radio signal it would FIX a lot of the issues encountered by owners who A) received a damaged or defective radio-controlled wall clock, and B) those who do not have good atomic signal strength in their location but for which the clock continues to attempt to make use of an intermittent (incomplete) signal. Alas, this is not how La Crosse Technologies designs these analog clocks to function in Manual Set mode, so when the signal is too weak or the hands are misaligned it will continue to try to reset itself but inevitably to the WRONG TIME. (My suggestion to the manufacturer is that they design these clocks to at least have the option to go on working correctly in Manual time set mode, as opposed to having one linked to the other in such a way that when the Radio Control fails the Manual set options also go awry.) Alas, the only real solution that I know of, short of someone obtaining La Crosse Technologies factory calibration instructions, is to DIY replace the radio-controlled quartz module with an aftermarket (non-radio) mechanism. Otherwise, a good percentage of these clocks that did not survive shipping or were not assembled well to begin with will not hold the time.
Posted on Oct 22, 2017
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
homedesigner
  • 583 Answers
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Posted on Feb 20, 2010
BillB-SA
  • 2761 Answers
SOURCE: I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Posted on Mar 19, 2010
dunnbiker
  • 8546 Answers
SOURCE: It looses time and the radio controlled feature
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Posted on Jan 25, 2011
dunnbiker
  • 8546 Answers
SOURCE: how to reset la crosse wall clock
It sets itself. You choose the time zone.
watch the video.
http://www.klockit.com/products/dept-52__sku-87109.html
Downoad a typical manual.
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
Posted on Feb 22, 2011
How do I set my lacrosse clock ws8055u
Press and hold Set (the top button on the right hand side of the clock) for 2+ seconds to enter the Programming mode. If the unit hasn't been set before "-5EST" should start flashing. Press + (the second button from the top) until the correct time zone is displayed. Press Set to save the setting and advance to the next program option. Again use the + button to set DST on or off. Press Set again to save and advance to the language choice (for the displayed day of the week). Press + to go through the choices and then press Set. Repeat the above steps to set the hour (if the clock didn't get the correct time from the WWVB radio). Note: PM will be displayed for the afternoon hours. There is no indicator for AM hours. Press Set again to save and advance to the Minute setting. Pressing Set again will bring the unit to set the Year, then advance to Month, then Date. The next press of the Set button will advance to setting the day of the week. The next items to set are the 12/24 hour time display and the units for the temperature.
If you press Snooze, on the top of the clock, or do not press a button within 15 seconds, the clock will exit the Programming Mode. LaCrosse has the manual for the WS-8055U on the product page: http://lacrossetechnology.com/8055/ . The direct link to the manual is http://lacrossetechnology.com/8055/manual.pdf . Make sure to replace the 2 AA batteries and position the clock where the radio signal is strong if the clock doesn't maintain the correct time.
I hope this helps.
Mar 16, 2015 | La Crosse Technology Radio-controlled...
Www.lacrossetechnology.com/8248 need to reset time!
I'm not totally sure what you mean by "reset the time" because the unit normally sets the time automatically from the WWVB radio time signal. If you want to do it manually, this is what the Instruction Manual (PDF format) says:
MANUAL TIME SETTING
In case the atomic clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
  1. The hour digits will start flashing in the upper LCD.
  2. Select the desired hours by pressing and releasing the + key.
  3. Press and release the SET key to advance to the minutes setting.
  4. Now the minute digits will start flashing.
  5. Select the desired minutes by pressing and releasing the + key. If the + key is held, the units
    will increase by 5.
  6. Press and release the SET key to confirm the Time setting and continue to the Year setting.
Nov 08, 2012 | La Crosse Radio Controlled Atomic Clock
My La Crosse Radio controled atomic clock is spinning for the last two days, How can this be corrected? I have a secound Clock same modle it is working fine. Modle# wt-3102
Hello
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
Ok.
Jul 31, 2011 | La Crosse Radio Controlled Atomic Clock
I set my clock to DST it keeps showing an hour advanced
The best solution to all these Zenith clock radio problems is to just throw the damn thing out and go to WalMart and buy the cheapest " anything but a Zenith" that they have.
Feb 03, 2011 | La Crosse Radio Controlled Atomic Clock
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
Jan 24, 2011 | La Crosse Radio Controlled Atomic Clock
I have a lacrosse technology wall clock how do i set the time
You don't set the time. You set the Time Zone and it sets itself.
What model is YOUR clock?
This site lists several models of La Crosse wall clocks with downloadable instructions.
http://www.klockit.com/depts/AtomicClocks/dept-52.html
The link below is generic but there are specifc downloads for clocks with other features.
Jun 18, 2010 | La Crosse Radio Controlled Atomic Clock
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
I need a user guide for a La Crosse WS-9211 Weather Station clock
Solved it! La Crosse let you download manuals from their website.
Nov 23, 2008 | La Crosse Technology E. Howard Ambassador...
Radio controlled clock won't set
it sounds like its working but its setting daylight savings time mine has an option to turnoff .that's makes scents if it always 1 hour off exactly.
Feb 15, 2008 | La Crosse Radio Controlled Atomic Clock
La Crosse Radio Controlled Atomic Clock Logo
1,076 people viewed this question
Top La Crosse Home Experts
John
John
Are you a La Crosse Home Expert? Answer questions, earn points and help others
