Question about La Crosse Radio Controlled Atomic Clock
I have tried setting my clock manually by following the directions. My clock will not set itself. But it always advances by approximately 1/2 hour after the manual set. Why?
4 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Posted on Mar 19, 2010
  • 5125 Answers
SOURCE: How do you manually reset a Lacrosse Atomic Clock.
There are many LaCrosse atomic clocks. Which model do you have? Support for most is available here: http://www.lacrossetechnology.com/support/home.php . Use the drop down menu to select the model.
For the analog clocks, there is a manual set button on the back of the clock. Press the button and wait for the clock to advance to the correct time. Then make sure the correct time zone button has been pushed. Then make sure the clock is in a location where it can hear the signal overnight. (For best results stand the clock upright in a window.)
For WT-2165U travel alarm, press and hold Set to enter the setting function. Then select the time zone (with + or -) then press and release Set. Set the DST setting to on or off as needed, then press and release Set again. The next setting option is the snooze alarm duration. Press and release Set again to change the hour manually (+ to increase). Press and release Set again to set the Minutes. Correct the date (year, month, day, day of week) similarly. Then set the display to 12 or 24 hour time. Press and release Set to finish and exit the set functions.
For some of the digital clocks you can set the time manually by pressing and holding Set. First set the time display mode (12/24), then press and release Set again. Then set the hours, followed by Set and then the minutes. Continue through other menu options or just do not press any buttons for several (30) seconds.
On the digital clocks, the item being changed will flash.
To avoid interference with the signal reception, place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal.
I hope this helps.
Posted on Feb 03, 2011
SOURCE: I set my clock to
The best solution to all these Zenith clock radio problems is to just throw the damn thing out and go to WalMart and buy the cheapest " anything but a Zenith" that they have.
Posted on Feb 04, 2011
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
How do I set my lacrosse clock ws8055u
Press and hold Set (the top button on the right hand side of the clock) for 2+ seconds to enter the Programming mode. If the unit hasn't been set before "-5EST" should start flashing. Press + (the second button from the top) until the correct time zone is displayed. Press Set to save the setting and advance to the next program option. Again use the + button to set DST on or off. Press Set again to save and advance to the language choice (for the displayed day of the week). Press + to go through the choices and then press Set. Repeat the above steps to set the hour (if the clock didn't get the correct time from the WWVB radio). Note: PM will be displayed for the afternoon hours. There is no indicator for AM hours. Press Set again to save and advance to the Minute setting. Pressing Set again will bring the unit to set the Year, then advance to Month, then Date. The next press of the Set button will advance to setting the day of the week. The next items to set are the 12/24 hour time display and the units for the temperature.
If you press Snooze, on the top of the clock, or do not press a button within 15 seconds, the clock will exit the Programming Mode. LaCrosse has the manual for the WS-8055U on the product page: http://lacrossetechnology.com/8055/ . The direct link to the manual is http://lacrossetechnology.com/8055/manual.pdf . Make sure to replace the 2 AA batteries and position the clock where the radio signal is strong if the clock doesn't maintain the correct time.
I hope this helps.
Mar 16, 2015 | La Crosse Technology Radio-controlled...
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
How to change clock
Setting the ClockIn order to set the clock, the ignition switch must be in the ACC position or in the ON position. The radio may be turned on or off.
In order to set the hour, perform the following steps:
1. Press and hold the down arrow button (HR). After approximately 5 seconds a beep will sound, and the hour will advance.2. Release the button when the correct hour appears.In order to set the minutes, perform the following steps:
1. Press and hold the up arrow button (MIN). After approximately 5 seconds a beep will sound, and the minutes will advance.2. Release the button when the correct minute appears.
Dec 01, 2011 | 2001 Chevrolet Prizm
How do i set the clock? I have tried many ways that i have been told and none work.
Welcome to FixYa!
Here is how to set the clock.
Initial Settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press M.C. and hold until CLOCK SET appears
in the display.
3 Turn M.C. to select the initial setting.
After selecting, perform the following procedures
to set the initial setting.
CLOCK SET (setting the clock)
1 Press M.C. to display the setting mode.
2 Press M.C. to select the segment of the clock display
you wish to set.
Hour-Minute
As you select segments of the clock display, the
selected segment flashes.
3 Turn M.C. to adjust the clock.
If you need the manual you can get it in the link below. page 11
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-2200UB_OwnersManual0922.pdf
Good Luck
Nov 09, 2010 | Pioneer DEH2200UB with iPod Direct Control...
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Oct 09, 2009 | Timex 1440 Nylon watch
No manual
Follow the procedure to set time/ clock.
Setting the clock
1. Press and hold CLOCK until
the hour flashes on the display.
2. Press << / >> to set the hour
and then press CLOCK to shift
to minute digits.
3. Press << / >> to set the minute.
4. Press PROG•SET to save
settings or STOP to quit setting.
You can download user manual at RCA Support.
Regards,
Sep 07, 2008 | RCA RS2663 Shelf System
Radio controlled clock won't set
it sounds like its working but its setting daylight savings time mine has an option to turnoff .that's makes scents if it always 1 hour off exactly.
Feb 15, 2008 | La Crosse Radio Controlled Atomic Clock
Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Nov 08, 2007 | Audio Players & Recorders
Timex T158W Alarm Clock
Hold down the "buzzer", "radio" or "sound" buttons until you hear a beep and one of those words is blinking. then, use the arrow keys to go up and down by minute and only by minute (which means you are going to have to wait awhile if you want to change the time to many hours ahead or behind). When you get to the time you want, press enter.
Oct 17, 2007 | Timex T309TT Clock Radio
La Crosse Radio Controlled Atomic Clock Logo
208 people viewed this question
Top La Crosse Home Experts
John
John
Are you a La Crosse Home Expert? Answer questions, earn points and help others
