Question about Office Star 8000 Pro-Line II Deluxe High Back Executive Leather Chair, Contour Seat and Back with Built-in Lumbar Support, One Touch Pneumatic Seat Height Adjustment, Locking Mid Pivot Knee Tilt Control with Adjustable Tilt Tension, Top Grain Leather, Padded Pol
Top tension adjust - Office Star 8000 Pro-Line II Deluxe High Back Executive Leather Chair, Contour Seat and Back with Built-in Lumbar Support, One Touch Pneumatic Seat Height Adjustment, Locking Mid Pivot Knee Tilt Control with Adjustable Tilt Tension, Top Grain Leather, Padded Pol
How to adjust tension
Find your manual as it identifies specific parts related to adjusting tension. Here are some pictures of problematic stitches and suggestions on fixing sewing machine tension:
How to Adjust Sewing Machine Tension on Craftsy
https://www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine
Sometimes you adjust something other than the tension:
Adjusting Sewing Machine Tension to Prevent Problems
How to Achieve Ideal Sewing Machine Thread Tension Threads
Dec 04, 2017 | Sewing Machines
How do I set the bobbin tension
How to change the tension on a sewing machine?
Adjust your top tension if it's too tight. To decrease your top tension if it is too tight, turn your knob so the numbers are decreasing. Try ½ to 1 number lower, then test the stitches on a piece of scrap fabric. Continue until it looks even on both sides and you can no longer see the bottom thread on the top.
How to Adjust the Tension on a Sewing Machine: 13 Steps
www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine Search for: How to change the tension on a sewing machine?
https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Sewing+Machines+How+do+I+set+the+bobbin+tension ..try this link
Dec 04, 2016 | Sewing Machines
How do you adjust everything in the bobbin casing is there seems to be a lot of adjustments and I'm clueless
Why are you wanting to adjust the bobbin mechanics? What is your machine doing or not doing that you think it should? Usually, tension adjustments are made on the top tension. Bobbin tension adjustments are seldom adjusted unless the top tension does not address the issue.
Nov 16, 2016 | Sewing Machines
How do I adjust the tension on the bobbin. My stitches are too loose.
Your objective is to have the top and bobbin tension equal. Once you have set the bobbin tension you will adjust the top tension until the knot is in the center of the fabric. A good starting point for the top tension is four.
I've attached a guide to help you set your tension.
Jun 02, 2015 | Sewing Machines
Model 1507 tension
I'm sorry, but you will have to be more specific. There is a top and bottom tension. The top tension is adjusted using a dial of some kind, visible on your machine. It has numbers on it; generally the lower the number, the tighter the tension. The bobbin tension generally does not need adjusting, although it can be adjusted. Please write again to let me know what it is doing that leads you to believe the tension needs adjusting.
Dec 11, 2013 | Singer 1507
Tension is messed up on my 96ksv7
Keep adjusting the tensions top and bottom until you get it right
Oct 27, 2013 | Singer 3116 Simple
How to adjust tension on bottom stitch?
There are tow places where the thread tension is adjusted.
One is bobbin. This is not routinely adjusted. Just once and it is good for long time. This is done by turning the only screw on bobbin by about 1/4 turn or so at a time. Try several settings until you find he best.
the other place is the conventionally on body of the machine.
Tension of bottom stitch or top stitch are very confusing words. meaning difft things to difft pple.
All i can say is this. If u see bottom stitch run straight through loops of top thread. then either top tension is too loose or bottom too tight. and vise versa.
With top tension set to middle position adjust the bobbin to get correct stitch. Then later on all u need is to adjust only the top setting according to stitch and cloth
Oct 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
Top tension adjustment
Believe it or not, most computerized machines have an automatic tension. This works well providing, the thread is thru the tension wheel setup.
But for further reference,
loops on the bottom-- problem on the top.
loops on the top--problem on the bottom.
Mimi
Apr 23, 2009 | Singer CE-100 Futura Computerized Sewing...
Bottom tension to tight
I found that sewing this type of fabric you should not have any pressure on the presser foot. and the top tension should be looser but note the tension before you adjust. and remember to make sure the needle is the right size for the fabric. and since wer are not to change the bottom tension because it always right?? then you may have to make the seam stitch longer good luck
Feb 23, 2009 | Consew 226R-1
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Office Star 8000 Pro-Line II Deluxe High Back Executive Leather Chair, Contour Seat and Back with Built-in Lumbar Support, One Touch Pneumatic Seat Height Adjustment, Locking Mid Pivot Knee Tilt Control with Adjustable Tilt Tension, Top Grain Leather, Padded Pol Logo
282 people viewed this question
Top Office Star Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Office Star Furniture Expert? Answer questions, earn points and help others
