Question about Kenmore Sewing Machines
Bobin tension issue 38515343600 - Kenmore Sewing Machines
  • Debbie Jun 05, 2015
    Hi Autumn Gaetano, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Kenmore Master
  • 1,860 Answers
Here is a link, contact this site about the Kenmore bobbin issue
http://www.ultimatesewingandvac.com/sewvacdoctor
Posted on Jun 05, 2015
My problem is with the bobin. The machine worked well two days ago. Now when I try to sew , the bobin thread is becoming caught in the lower area and produces tension that stops the machine after about two...
With out looking at the machine it is hard to determine the exact problem, but make sure your bobbin thread is placed in the bobbine case corretly, and pulled through the little tension area on the bobbin case.
Next make sure the upper thread is in the tension discs, if not this can also cause you a problem, plus if possible used a little canned air (with the pressure foot up, machine unplugged and thread removed) blow out the tension area.
Good luck.
Mar 12, 2011 | Brother SE350 Mechanical Sewing Machine
Sewing with heavy thread, what should the tension be set on?
hi there
the tension depends on thikness of material but you must use heavy thread on needle and thin thread on bobin case .
- you must be sew fiew stitches firist and look if losse stitch from down you must tight tension slowly sloly and if there is losse stitches from upper you must tight screw for bobin case spring slowly slowly until stitch format be agood condation.
best regards
ashraf abozid
aabozid@hotmail.com
Jan 06, 2011 | Juki DDL-8700
Top thread keeps breaking during sewing. Tension adjustment does not solve the issue. Also, machine is skipping stiches and will not sew anything but a straight stitch: needle moves in the ziz=zag or...
This could be more than one issue, first I don't think you have the machine threaded correctly. Make sure when you thread that the thread is seated betweeen the tension disc on the top and also, make sure that you have properly but tin the bobin
Aug 13, 2010 | Husqvarna Sewing Machines
How to stop bobin thread from knotting
When loading the bobbin there is most likely not enough tension on the thread letting it overlap incorrectly. Try wrapping thread around a tensioner when filling and that should help. That way the bobbin is rolled as tight as the tension on the upper thread when sewing.
Apr 13, 2010 | Brother LS-2125 Mechanical Sewing Machine
The bobin thread keeps showing through I don't
Make sure thye top tension is about 4 or 5, tighten the bobbin tension screw on the bobbin case about a quarter of a turn at a time clockwise and test until you get it right
Mar 22, 2010 | Sewing Machines
How do I tighten the tension on the bobin thread I am quitiing with invisible thread on the top and dark blue on the bottom, the bobin thread shows. I don't want that
you can either increase the bottom tension or reduce the top tension .. you will notice a little screw on the bobin case ... that screw adjusts the force on a small flat spring which provides the bottom tension (the thread goes under the spring when properly threaded) .. .. tighten that screw a little to increase bottom tension .. you can pull thread thru the bobin case to get a feel for how much tension you have ... you dont have to turn the screw very far to make a significant difference .. try just 1/4 of a turn at a time .. remember where it was originally set so you can put it back when you are finished with your present project .. the greater the bottom tension the less bobin thread will show at the top ... if you get the tension too high then you might see some puckering as you sew ..
Jan 03, 2010 | Sewing Machines
Lower thread tension is too loose but no adjustment seems to work
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Nov 28, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother Industrial Machine Tension
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
Nov 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Thread is clogging up under fabric and is not catching bobin thread
I have the same problem, I fix it by removing both Shuttle hook and Bobbin Case and tested it to see if the shuttle hook rotated freely within bobbin case. I noticed the screw for the tension spring was too high and was rubbing agaist bobbin case. Just tighten screw on spring and and recheck for rubbing.
Sep 06, 2007 | Kenmore 15343
Sewing Machines Logo
42 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
