Question about Thetford Refrigerators
Thetford n175 fridge, has a code 12 error on both mains and gas. Auto is still showing but not working on any source of power.
    Top Expert:
  • Thetford Master
  • 7,905 Answers
Check fusible link on back wall by chimney then 12 volts to control board
Posted on Jan 11, 2018
22yooper
  • 828 Answers
SOURCE: Thetford Fridge N112
There is a very likely possibility that the resistance heater for the 12 Volt side of the operation is open. This heater can be checked for continuity using an OHM meter from the terminals for the 12 volt .
Posted on Jun 02, 2008
  • 68 Answers
SOURCE: Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Posted on Mar 24, 2009
Healeyman
  • 1198 Answers
SOURCE: fridge will not work on gas
If you're sure the gas is igniting and making heat, you may have lost your refrigerant. It probably is ammonia, which smells very strong. Check your dealer for someone who can check it out.
Posted on Apr 27, 2009
  • 8 Answers
SOURCE: I have a Thetford N112 which will not cool the
un plug the heating element from the circuit board and ohm it out. also check fuse on board. but sounds like the heating element has gone out. if when you ohm it its on 0 its bad
Posted on Aug 27, 2009
  • 884 Answers
SOURCE: I have error code 8 on thetford fridge how do I remove code to used on 240 v
If switching off and on again doesn't clear fault 8 (ac volts 20% lower than spec) you may need to replace the board for one with a resetting fuse.
Posted on May 20, 2012
Thetford caravan fridge N614F won't work on 12v red light showing on/off switch.
2 possibilities.
bad 12v fuse on refrigerator od bad power supply board
Mar 03, 2018 | Thetford Refrigerators
My thetford n3112 fridge flashes when on mains?
check 12 volt from converter if ok check 12 volt to back board
Mar 23, 2017 | Thetford Refrigerators
Thetford N80 fridge will not work on mains
check fuse inside control box of fridge then check heater elements
Jan 19, 2015 | Thetford Refrigerators
I have a thetford N112 fridge which works on gas but not on mains, the element heats up but fridge does not cool
Hope this answers all your questions
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 16, 2012 | Thetford Refrigerators
Thetford fridge wont work on mains power
start by putting the fridge in a cold place or if that don't work then turn the temp down inside the fridge
Dec 19, 2009 | Thetford Porta Potti
Fridge will not work on gas
Apr 27, 2009 | Refrigerators
Jun 02, 2008 | Thetford Refrigerators
Refrigerators Logo
210 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
