Question about Rainbird Rain Bird 6 Station Automatic Triple Program Sprinkler Timer Ism-6rs In Box
How do I advance the LCD screen on my sprinkler system from the off position?
I have replaced the battery; still no change.
  • 2,963 Answers
Looks almost new? warranty? Have you had lightning nearby? These things don't have much serge protection and a spike will kill the board. Otherwise Owner's manual troubleshooting? Or store? Or MFG web site and Customer service email
Posted on Apr 11, 2015
Why is replacement sprinkler head leaking?
If water pressure is over minimum recommended rate, your replacement sprinkler head shouldn't leak; it it's leaking probably because it is of a very bad quality. If it's new, return it to the shop where you bought it and clim your warranty right
Sep 13, 2015 | Garden
How do I get my Hunter ICC irrigation control box to turn on?
Check batteries with tester. Check internal fuse (sometimes same compartment as batteries. May have have to spend the $20.00
Jan 18, 2015 | Hunter ICM-400 ICC 4 Station Sprinkler...
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jul 27, 2011 | Intermatic R8806P101C -...
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
Sprinkler System reads PR OFF
You need to reprogram your timer, as whenever you change the batteries, several maker's timers lose the program you've put into them. The PR OFF means the Program is turned OFF and you must re-enter the start and stop times and day(s) you wish to have the sprinkler system runnning.
Hope you find this Very Helpful and best regards.
Aug 24, 2009 | Hardware & Accessories
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Rainbird Rain Bird 6 Station Automatic Triple Program Sprinkler Timer Ism-6rs In Box Logo
565 people viewed this question
Top Rainbird Garden Experts
Ted Maxwell
richie46
Gil Shultz
Are you a Rainbird Garden Expert? Answer questions, earn points and help others
