Question about Pentair Pool & Spa
I cannot manually turn my pool off and on. I'm sure it has to do withe the settings. Del shows on panel. Its the weekend so no pentair rep is available.
    Top Expert:
  • Pentair Master
  • 8,177 Answers
Put in service you should be able to control manually
Posted on May 16, 2015
  • 128 Answers
SOURCE: under water pool light not coming on
Check the GFI on the side of the control panel.
Posted on Aug 30, 2009
  • 128 Answers
SOURCE: minimax pool heater cuts out at 91 degrees when remotely set for
Check the temp reading on the heater. It is probably set at 91...heater control should be set to 104
  • 246 Answers
SOURCE: Searching for Operating Manual for natural gas pool heater.
pentairpool.com
Posted on Sep 18, 2009
  • 990 Answers
SOURCE: We have a Pentair 400 heater. First time to heat
You probally just need to increase your water flow. On the pipes going to the heater their should be a valve bridging the inlet and outlet pipes. This valve should be closed about 80-90% so it forces more water through the heater. I hope this helps.
Posted on Jan 02, 2010
SOURCE: Our Pentair control panel is
Temp sensor is bad.
Posted on Jun 22, 2011
My pentair intelliflo 011018 won't show me settings on led panel any more, but everything else is ok. Have to manually start and stop?
You will need to replace the drive. The drives are not an item that can be repaired. How old is the Intelliflo? Your pool guy should be able to help you with a replacement. If you are a DIY type person here are some links to replacement drives.
https://www.sunplay.com/pentair-variable-speed-drive-assembly-kit-350721?gclid=CjwKCAjwhYLLBRBIEiwAtFeED9LVg06N31VP_PG-_b14viceSaOTBBB6soBvYmdnqCcx5XRFunnCxBoCwrgQAvD_BwE
http://www.ebay.com/itm/Pentair-Drive-Assembly-Intelliflo-Vf-3050-Kit-Almond-350721-/302363409067?_trksid=p2385738.m2548.l4275
I would make sure that you call and confirm that you have a VF or a VS pump. F=flow and S=speed. Also make sure you do not have SVRS vacuum entrapment protection built in to the drive. If you do you'll need to contact Pentair directly.
Jul 07, 2017 | Pentair Pool & Spa
Easy touch control system temperature set at 75 but heater does not change from manual setting
make sure the temp on heater is set at 104. otherwise easy touch panel wont override manual setting from the heater. if you press the mode button on easy touch panel, and it doesn't change, then one of the relays inside the panel is the problem
May 15, 2014 | Pentair Mastertemp Heater
I have a pentair master temp 400 that is 3 years old. It is turning on by itself when the pool timers kick on. The temperature changes from say 54 degrees to 240 degrees. When changed from pool settings...
You heater has brain damage. I wish I had better info for you but this heater has been a consistent source of aggravation for pool techs.
Sta-Rite, a division of Pentair acquired about 12 years ago, manufactured the heater under the name MaxiTherm (and still does).
Pentair decided to make their own version of it and unfortunately they are hard to keep running. I don't know what they tweaked but they managed to wreck one of the best heater designs out there.
A tech can come out and change the malfunctioning parts but it won't be cheap, and very likely will have to service it again within a relatively short period of time.
I'd advise to get in contact with your local Pentair rep and see if you can get any credit toward the Sta-Rite version. For what these things cost you have to demand better performance.
Jan 15, 2014 | Pool & Spa
Pentair Pool Heating Rapidly Increases Temp on Panel then shuts off.
Check the Thermal Reg in the header and also make sure you have adequate water flow thru the heater, make sure your filters are clean and there are no external by-pass valves open.
If you remove the Thermal Reg in the header and the heaters seems to run fine the replace with a new one.
May 03, 2017 | Pentair Minimax NT Heater
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
Compool TimeMaster with this control panel Picture: http://is.gd/juMkm Manually turning on or off pump/lights/spa all work, but the auto timers fail to start or stop any functions. Any ideas? ...
The first thing that I see is if you have a service panel, make sure that it is in "auto", not "service" and that all switches are set to off. That is the panel by the pool/spa, not the main panel.
Gary
Dec 26, 2010 | Pentair Pool & Spa
We cannot program the system inside the house. It is showing ERR 4 - We need the manual to show us what to do. The motor number is Compool CP-3600.
Turning on the spa side remote will remove the error code.Pentair will send you a new manual if you ask for one.
Sep 26, 2010 | Pentair Pool & Spa
Pentair Easy Touch remote lost sync with the outside unit. Have tried resyncing a dozen times, per the manual, tried hitting the reset button and then resyncing...nothing worked. I removed the cover on...
Try turning the whole system power off at the main house panel, wait a minute, turn power back on, then go to the pool panel and reset communication as per manual instructions. This worked for me.
Sep 25, 2010 | Pentair Easy Touch Indoor Control Panel...
Periodic stop/restart
I had a similar problem for a year and spoke to the pump designer. We ultimately solved it as there was a spring valve in the heat pump I have. ANy type of spring valve is a problem for the intelliflo as the pump is tooo intelligent. When the spring opens and closes it makes the pump think that there is a blockage and it reacts by shutting off.
The solution is to replace all spring valves although I was able to use a manual valve just before the spring valve to reduce the flow so that the spring would not move and thus impact the pump.
Nov 02, 2009 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pool & Spa Logo
131 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
