Error code 33 spin what to do?
Machine used once only a coin was found in the bottom pump assembly removed and now it does not want to run indicates now error code 33 ??
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pump impeller,s not worn away
Posted on Apr 13, 2015
Where is the coin catcher on a Kenmore Elite H3 washer
it is most likely the pump. you can remove the pump and debris trap easily, separate the pump from the debris trap by depressing a tab and turning the pump clockwise from the debris trap. the pump is a mag drive unit and is easily dis-assembled. ours had debris inside the pump, once taken apart there was some black colored fine sand inside that once cleaned out the pump returned to normal function. we bought a new pump but the old one still works since it was cleaned out, the rubber o ring had leaked letting the debris inside the impeller assembly. hope this helps out. it worked for ours
Dec 03, 2017 | Kenmore Washing Machines
Nd code and door locking
There could be another coin in the drain pump, jamming it.
With power disconnected..........Does the pump turn by hand in both directions?
Nov 21, 2017 | Maytag NFW7200TW Front Load Washer
I found coins in pump and removed but still not draining correctly
If all obstructions are removed, and still doesn't drain, replace pump.
Sep 05, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer tub does not turn after it has let the water in
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Mar 27, 2013 | Frigidaire Washing Machines
Maytag epic z washer error code F21-have unplugged for 15 mins. and removed front panel and drained and found some coins and removed BUT it worked for a few mins. then the error code reappeared. what is...
F21 indicates a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump.
You may have something getting caught in the pump impeller and slowing it down. Or, you may have something clogging the drain lines. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If this solution doesn't solve your problem, you may have to replace the drain pump.The error code will continue to appear until the pump is replaced.
Thank you !!
Aug 01, 2010 | Maytag Washing Machines
Gets an e10 code after just a few minutes after start. water pressure is good and the machine is level
this is a general error code usually indicated a block drain pump.
If you still have water in the tub you can use a wet dry shop vac and attach it to the end of the drain hose and remove all the water.
Once you have removed all the water then ou need to remove the hose that runs from the bottom of the tub to the drain pump remove the plastic coin trap and clean out and foreign material.
you have to remove the lid first then take the main control panel off then remove the front panel,dont forget to take the rubber boot off the front panel.once this is removed you will see the drain pump lower right side of the tub.
Feb 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Machine will run through entire cycle and will not spin. It quits at the spin cycle. I checked the Black boot at the bottom. Removed and cleared out coins. Checked pump- it was turning freely. Reinstalled...
I had a similar problem and found out the "latch" on the washer door broke off. The machine won't run in spin cycle if the door is"open", but it would run through the wash cycle.
Feb 05, 2010 | Frigidaire Washing Machines
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Nov 20, 2008 | LG WD-1280FHD Front Load Washer
E20 Error Code
Greetings jeanne1568,
Other consumers have reported this error message and found it relates to your "Coin trap assembly" being blocked, therefore not allowing all the water to pump out. The suggestion out there is to remove the front access panel, and remove the clamp that connects this trap assembly to the pump and clean it out.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Jun 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool duet washer sport ht - error codes
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
May 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
