Question about Daewoo Washing Machines
Need to purchase a timer for a daewoo dw 160 washing mechine
    Genius:
  • Daewoo Master
  • 1,585 Answers
E spares.com
Posted on Apr 12, 2015
3 Suggested Answers
  • 6277 Answers
SOURCE: hi, how to repair daewoo
TRY THIS FIRST, PLEASE!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 27, 2011
caroldon
  • 17130 Answers
SOURCE: -I have a Daewoo washing machine DW F1251S with OE error code. What doesthis mean?
Possible this is relative of a poor drain time which means a clogged draining pump and system. So it si best to remove and clean the drain pump/filter and reset.
check if the machine drain hose is connected to a outlet which is not clogged when the water is flushed out . Also the washing machine must be slightly tilted to drain to the pump to reduce the drain timing.
Finally check if the machine was overloaded to produce a strain on the motor so as to give an error. If so shut down remove plug remove load , check if the agitator is jammed and reset.
Posted on Nov 21, 2011
Is vltage 110 or 220 volts
Would that not depend on which country you bought it and where you are trying to use ? Check the back of the Washing machine for voltage details.
the manual is attached. DAEWOO DW 160C Instruction Manual
Apr 27, 2016 | Washing Machines
Nov 21, 2011 | Washing Machines
Hi, we have a Bosch SHU53EO6UC/14 dishwasher. It is getting stuck in wash and isn't advancing. We think it may be the timer but there are lots of references to running a test program. Unfortunately...
My Bosch DW SHU5302 also got stuck during a cycle and ran and ran. Turns out this is a known problem with these DW's. The problem is that a trace on the main board burns off that controls the heater. If the heater doesn't come on then the DW keeps running waiting for the water to heat up. Re-soldering this trace fixes this problem. If you get a repair guy out, he will only change the board. They are not allowed to re-solder which doesn't fix the problem for long as the same trace will burn off. Did this about 8 years ago and it is still fine.
Aug 29, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
My daewoo washing mechine door can not open after washing why?
There may be pressure on the door causing it not to unlock or check if the lock is bent or off set.
Mar 20, 2011 | Air Tools & Compressors
Wasing mechine does not stop spining after draining water &keeps spining ,does not stop automatically untill i stop manually eitherby opening the lid or pulling the knob
You need to replace the timer switch on your machine. If you will post your Maytag model number I can direct you to the part you will need.
Happy Holidays
Dec 13, 2010 | Maytag Washing Machines
Hai hope you will answer me our washing mechine we bought 6 month before front loading and i do not want the heater the temep makes colour comes out and how to stop 30 or i put in feather touch all...
Hello Blessy, the problem is that the machine is pre programed tp give you a certain temperature depending on what program you select. If you disconnect the heating element, the timer will not move on in the program and it will stay in one place washing all the time. Basically, you need to purchase a machine that has a seperate temperature thermostat which you can manually set to low if you wanted.or a top laoder that has a hot and cold water inlet. You could just connect the cold water tap.
Sep 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washing mechine Timer not working
look online for appliance parts give model no. and u should find it
Aug 28, 2009 | Whirlpool Washing Machine Knob - 3362624
Washing Machines Logo
50 people viewed this question
Top Daewoo Washing Machines Experts
dweatherby
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
