Not all televisions have a factory reset feature and if they do, it normally only resets customer set settings. If you have suffered a power surge, the electronic components have failed and need professional repair Charlotte.
https://www.hardreset.info > devices > ferguson-s3
The following tutorial shows all method of master reset FERGUSON S3. Check out how to accomplish hard reset by hardware keys and Android 4.0 Ice Cream ...
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Set-up codes to Ferguson are 0279,0277,0271. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter". http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. https://homenol.blogspot.com/ https://remotesearch.blogspot.com/ https://electronicshelponline.blogspot.com/ https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device./
After 5 years, and you have tried to set it up again, its probably had it.
Turn off all power to it for 10 mniutes then carefully do the setup again. If its still bad its time to replace it.
This is guesswork but you are probably using the wrong encoding scheme. I'm assuming you're tyring to burn a DVD. Look in your DVD burner software for an option labelled VCD or NTSC VCD.
If you have a multimeter you should be able to check the out voltage on the powersupply to make sure the power cable isn't at fault. You may also try wigling the power cord a little bit to see if the unit will then get power. If so you have a faulty powercord.
If there are any fuses they should usually be accessible from the outside; that's the point with them - they should be easy to change. I would put my money on the power cable.
If you have access to a diferent power source try that out. If the unit works with a different power source your power source is at fault. If it still doesn't work the problem is within your unit.
Check to see if any pins on the power source and/or the units power plug might be bent or dirty.
