Question about Cameras
Bracelet needed shortening
New watch sent to CIS 19 March when can 'I get it back. now over 3 weeks
  • 2,355 Answers
Contact CIS and ask when you will get it back.
Posted on Apr 11, 2015
How to shorten the watch band without breaking it
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Apr 09, 2009 | Citizen Eco-Drive BL5184-56L Wrist Watch
How do I shorten the watch band?
Job done!
Mar 28, 2009 | Watches
Can't set day of the week for armitron MD06117 mens watch
Purchased my Armitron men's digtal watch in 2009. Here's the twist on setting the name of the Day of the Week on my watch. When you get to the name of the Day of the Week flashing.. you don't get Su...Mo...Tu... You get 01..02..03... up through 99. (You think.. what the hell is this??) DON'T TRY TO SET Sun.. Mon.. etc here.. you won't find it. The puzzle solver..and it is.. IS TO SET THE LAST TWO DIGITS OF THE YEAR HERE.. Example... it is now 2010.. so scroll thru the numbers and set it to "10"!! Now.. when you go and set the numerical day date e.g. 3 for March, and set the numerical day - e.g. 15, the on-board computer?? in the watch will AUTOMATICALLY SET THE NAME OF THE WEEK!! It will look-up For Example.. in the year 2010.. 3-14 is SUN.. and will set it as that!! Hope this saves you some frustration. Regards... klsdad@mindspring.com (Mar 14, 2010)
Mar 06, 2009 | JCPenney Armitron Sport Link Bracelet...
How to shorten a wrist banc for a TB4008 watch
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
Jan 09, 2009 | Tommy Bahama Island Palm 2 Tone Link Watch...
Shortening stainless band for 1st generation Tissot Le Locle
Job done!
Jan 04, 2009 | Tissot Le Locle Automatic Chrono Large...
Shorten band
Hi Go to www.skagen.com top r/h search box - input your model number click on go,
On the new page at bottom/left, click on customer service.
On new page left side click on instructions.
On new page you will find instuctions on how to shorten/lengthen bracelet.
Oct 24, 2008 | Skagen 107SSSBD Wrist Watch
Compatible ink
yes i have a epson rx560 i brought a contiouous ink system the thing you must watch out for when buying copy ink is that they work with all modles or rx560 as some ink will only work befor printer made before 1 march 2007 and some will only work after made 2007
but the continuous ink system will work wit all models i can get cis for £45 plus postage and come with 6 x 100 ml ink contact me if your intreasted
Oct 11, 2007 | Epson Printer
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
