Question about Singer 6160 Sewing Machine
Can anyone help with problem sewing button holes in a waistcoat?
This is with the automatic function. It is OK with just a couple of layers of cloth but with two thick layers and interfacing the thread bunches up underneath and I get a short or mis-sharpen buttonhole.
  • Singer Master
  • 1,860 Answers
Some sewing machine are not made to sew thick layers of fabric, the only suggestion I have is to try a new needle, make sure the top thread has not come off the thread take up lever, rethread the machine top and bobbin.
Posted on Jun 03, 2015
  • 26 Answers
SOURCE: thread bunching underneath
clean the lint out with canned air and check the bobbin holder for any possible needle pieces from breaking a needle maybe the needle is bent and you can't see the slight bend.may need oiling too
Posted on Mar 08, 2009
yeroc
  • 397 Answers
SOURCE: thread bunches up
check bottom tension...but first make sure your threading machine correctly
either bottom first or top tension....top tension should be set to 4-5 bottom should feel when pulling about the same tension
Posted on Nov 24, 2009
  • 1116 Answers
SOURCE: I am trying to sew buttonholes with the one step
There doesnt seem to be a reason - you are doing everything as it should be - lever down to stop the foot according the the button size is the most overlooked step.
I would take the buttonhole foot off and see it is moving as it should. Don't force as the plastic parts can break and then try again to make the buttonhole.
If you still cannot make the buttonhole, the problem may be the control switch and this would have to be checked by a Singer Sewing Machine Tech.
Check your warranty - faulty switches are covered for two years, but you pay the labor.
Posted on Mar 29, 2010
  • 48 Answers
SOURCE: My automatic buttonhole attachment won't make
This is not the problem of the thickness, but of the softness. Fleece will pull unevenly, causing the dogs to simply tug at layers of it in place, instead of moving it. You will have to (GENTLY) assist the dogs in moving your fabric, if your fabric is this soft.
The cause of this is 90% on the fault of the fabric, and 10% on the way the buttonholer foot works. The foot is built to hold the fabric fast in place, with sliding action only permitted by the buttonhole guide. However, this is assuming the dogs can get enough purchase to move the fabric around. Simply put, again, you will have to help the dogs along with this one(you will be able to clearly feel the difference and which way the dogs "Should" be moving at the time when you attempt to, as once it catches in one direction, it is likely to keep going in that direction until the dogs stop.)
Posted on Apr 21, 2010
SOURCE: bobbin thread bunches up
try changing the needle
make sure the bobbin is inserted correctly in the bobbin case
clean under the needle plate & in the bobbin area for lint & loose threads
make sure the bobbin is wound correctly
make sure the thread has not come off the thread take up lever
Posted on Mar 29, 2012
Hi I am wanting to do a 4cm buttonhole on my Elna Elina 40. The automatic button hole only goes up to 2.5 cm. How do I do a button hole as long as 4 cm please.
Just stitch the buttonhole without the automatic buttonholer. That's how we do it with machines that don't have the buttonhole function. Buttonholes can be done on any sewing machine that has zig-zag capability. A left/right needle position would be helpful, but if that is not available, just be sure to sink the needle into the fabric BEFORE changing the zig-zag width.
How to sew buttonhole with an old machine
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Buttonholes without using special feet or cams YouTube
Feb 11, 2017 | Elna Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
I can''t remember the steps to make a button hole using my Bernina patchwork 140. I have the # 3 foot. What button do I push to turn the corner manually?
you can download a manual for the Activa 145 here, buttonholing steps would probably be very similar for your model
http://www.bernina.com.au/webautor-data/888/0305295204_0303_a135-a145_EN.pdf
It says you sew one bar, then press the reverse button and the automatic function then sews the bar tacs, other side, bar tack and finishes.
Jan 29, 2011 | Bernina Activa 140
Button hole
I worked for two hours and kept getting terrible button holes.. the back side has loose thread while the front looks OK. I finally went back to my 30 year old Bernina to complete the button holes....
Does anyone know how to fix this problem?
Jun 27, 2009 | Singer CE-100 Futura Computerized Sewing...
One step button hole instructions Singer model 3827
Insert the button into the special button hole foot. put the foot on the machine.Pull down the button hole lever( It's near the presser foot lever towards the back of the machine). Place your needle where you want the button hole to be. Select the button hole pattern and press on the pedal. Watch for the end of the button hole.
sewman7
May 15, 2009 | Singer 7422
Automatic Button Hole
perhaps look up the user manual online, or get in touch with your local dealer.
Apr 08, 2008 | Janome Memory Craft 4800QD
Hi, Could I get a copy of your manual? I rec'd my mom's Janome Harmony 2049 when she passed away in Dec but no manual was found. Thank you! nreublin@jps.net
Jan 03, 2008 | Janome 2049LX Mechanical Sewing Machine
Buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is determined...you lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Jan 06, 2007 | Juki HZL-E80 Computerized Sewing Machine
Singer 6160 Sewing Machine Logo
51 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
