First you need to eliminate a failing hard drive as being a possible cause, then take it from there depending on the test result.
You'll need to make a boot CD containing the drive manufacturer's disgnostic software for DOS, then boot your PC from that CD.
The links for diagnostic software are here: http://www.tacktech.com/display.cfm?ttid=287
(copywrite Phillip Corcoran)
SOURCE: Problem with Installation of Windows 7 on Acer Laptop
Have you checked with Acer that your pc can accept Win 7.0?
if its not compatible then you may be floggin a dead horse with it, I doubt there will be many Win 7.0 drivers available yet for older systems but you may be lucky.
SOURCE: computer restarted unexpectedly or encountered an
Please explain the error. Mostly its because Windows couldn't access some particular area in RAM.
SOURCE: function key doesn`t work with windows 7 installed
My Vaio model is VGN-FS840 and after I formatted by laptop, my function key is not working, what shall I do to make it run? Can I download the driver? is it available in websites?
SOURCE: I have a 64 bit compaq presario c700 with windows
Go to Microsoft.com and DL the patch for it.
SOURCE: I have an an acer aspire 5336-2524 i tried to do a
You can try using a different Operating system disc.. completely format the hard derive before reinstalling the Operating System..
Thank you
To format the hard disk and re-install Windows use the Windows installation CD, and the Windows Product Code on the label at the bottom of
your laptop.
Boot up using the Windows installation CD and follow the
instructions.
One of the installation early steps, the option to delete the existing partition, then create a new partition and then a full format on this partition (don't do a quick format) and complete the Windows installation.
Next install all of the Toshiba's computer/laptop device
drives.
Next install the Windows service packs (SP2 & SP3 for
XP, SP1 & SP2 for Vista)
Next Activate Windows via the Internet or by phone.
Next install your programs - Microsoft Office etc.
Next
click on Start - Programs - Windows Update (for the latest updates).
