Question about RotoZip Roto Zip RZ1500-35 5.7 Amp Keyed Rotary Spiral Saw Tool
My roto zip revolution had a bad power switch. It works if I play with it. I sprayed it with cleaner but nothing. Can anyone fix it?
    Top Expert:
  • 46,218 Answers
Quite possibly the manufacturer .
Posted on Apr 11, 2015
  • Bill Brown
    Bill Brown Apr 11, 2015
    No disrespect but duh... That was my 1st call. The company was sold to Boshe and they don't support or offer repairs for this device 'Revolution'. They offered to sell me a new one :-)
How do i fix the play button on br-900cd does not engage when pressed
Try non conductive electronics spray contact cleaner,
I have used this for many similar repairs,
hope that helps? RadioShack TV Tuner Cleaner Cleaners RadioShack com
Mar 08, 2015 | Roland Boss BR 900cd Digital Recorder BR...
Hi my sh ge90 equaliser has started to make a funny noise.it works but it's making the sound really bad can anyone help?
It could be dirty contacts , try buying a spray switch cleaner , and moving the switches.
Oct 15, 2014 | Audio Players & Recorders
Power is not coming on
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
Griddle stays on
Check the on / off switch and see if it is bad. Make sure it is unplugged from the wall. Sometimes you can use electronic contact cleaner from the auto store and spray the switch and then then turn it off and on several time with the unit unplugged and that will fix it. If not it could just be a bad switch.
Dec 06, 2011 | Stoves Ovens
My new behringer dr600 guitar reverb pedal is cutting in and out (in time to its reverb setting) after an hour +/- of playing. very psychedelic all of a sudden, but not what i had in mind... it's...
hi,
you should clean the pedal switch with a contact cleaner .spray it on the switch and push the switch repeatedly to clean the contact much better if you replace the switch with anew one.there is also a trimmer pot at the circuit board of your reverb adjust it slowly to then return to its original position just to renew the contacts..you can use electra contact cleaner.it is available at hardware and electrical supply..
Aug 08, 2011 | Audio Players & Recorders
Green light on MB but will not power up at all nothing, even if I hold the button on. Emachine T3958 about 5 years old.
first thing I would try is a new power supply. if that doesn't do it for you, it's most likely your motherboard is bad.
Feb 13, 2010 | E-Machines eMachines Desktop PC
Drill starts and stops like there is something loose on the inside
This is typically caused by one of two things. Worn brushes or a bad switch. How old is drill and has it been used a lot? If the brushes are worn/bad they will need replacing. If the switch (trigger) is bad it can sometimes be fixed by spraying an electronic contact cleaner in it. This cleaner can be purchased at Radio Shack. I have also had good success using WD40. Spray the switch down good (power removed) and manually operate it a few times, wipe it clean, plug it in and try it again.
Nov 16, 2009 | Black & Decker 3/8" Variable Speed...
My 4-year old polaris 380 frequently blows internal tubing off ports. Do I need to reduce water flow at the hose inlet?
Once you fix the immediate problem with zip ties, check the wheel RPM. It should be between the range of 28 to 32.To check the RPM Hold the cleaner completely under the water and count the wheel revolutions for one minute. If your RPM is to high, you can adjust it at the wall with pressure relief valve by unscrwing it. Im willing to bet your pressure is excessive. This page should also help: Polaris Troubleshooting Page
Nov 02, 2009 | Polaris 380 In Ground Pool Cleaner
Play/Stop button on base is stuck on cordless telephone
Buy a spray can of electronic cleaner. Disconnect from power, spray and exercise button(s) at the same time. Let it dry, plug it in and see what happens.
Mar 25, 2009 | Uniden Cordless Phone
DEAD LEFT CHANNEL!!
The most common problem is a dirty record<>play switch inside the unit. Try this: Using a blank tape, press and release record/play buttons several times. This can clean the switch a bit. Then play a tape. If it fixes the problem, then you need to take the unit apart and use a plastic safe spray cleaner on the switch (Check at Radio Shack, their tuner cleaner Catalog #: 64-4315 will work fine). Spray it into the switch and then work the switch with the buttons several times.
Hope that helps...
Geno
Apr 04, 2008 | Audio Players & Recorders
RotoZip Roto Zip RZ1500-35 5.7 Amp Keyed Rotary Spiral Saw Tool Logo
649 people viewed this question
Top RotoZip Drywall Experts
Tim Hunt
Tim Hunt
ray gallant
Bill Boyd
Are you a RotoZip Drywall Expert? Answer questions, earn points and help others
