Question about Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range
My oven keeps switching off
Just cuts out. No display, display flashes back on, put cooker on, then the same happens again
    Top Expert:
  • Cannon Master
  • 10,875 Answers
Main board problem, http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Cannon/Cooking/10430G_10475G_10476G_10682G_10685G_10688G_19504477602.pdf
Genuine Parts & Accessories UK: 08709 077 077 Monday to Friday, 8.30am to 5pm Saturday, 8.30am to 12noon www.cannonservice.co.uk Republic of Ireland: (01) 842 6836
Posted on Apr 11, 2015
Why is my oven cutting out
If your oven is cutting out and this goes for anyone else experiencing the same problem.
If this is happening WITH ONLY THE COOKER. then either you will need the item looking at for proper earthing OR you will need the wiring checked for the cooker along with the RCD to which the cooker is connected as these can SOMETIMES be faulty.
Does the same happen if something else is plugged into the same socket??? If so then the socket and the wiring to the fuse board/ distribution board / consumer unit must be faulty or the earthing
Dec 14, 2015 | Ovens
Stoves 720G Manual
SOMEONE POSTED
However...I discovered the little buttons on the timer come out completely. So I used a cocktail stick to poke about inside the holes where the buttons go till the Auto mode light disappeared and the cooker went back to manual. And my oven works again as before.
Jan 04, 2015 | Stoves Ovens
My display is broken so I cant put oven on any advice
Had a similar problem over a year ago on my Rangemaster, neither of the ovens would come on, only the gas hob worked.
The cost of a new display unit was around £100 plus so decided to check out the unit by removing it (it was quite easy to do; but remember to isloate the cooker from the mains before you start dismantling).
On my display there were six wires plugged into it. I marked each one and the display before removing them so that they all went back to the correct location (i am not an electrician and am therefore an electrical numpty).
Firstly I degreased each male and female connector using an electrical spray degreaser/cleaner and then cleaned them using very fine emery paper and a special pen with glassfibre bristles until they gleamed and then gave them a final spray to remove any debrie left by the cleaning process.
Before i put everything back i also cleaned all the connectors to the switches etc which were accessable in a similar manner; about another eight/ten in total.
Following reassembly and switching the power back everything started working again. All this work took about an hour and my cooker has been working fine for the last 12 months.
Nov 16, 2014 | Ovens
Oven light switching on and off
which model is it?
switch it off at the mains ie fuse boad...label cooker switch....for 10 seconds, then back on.
Sep 04, 2014 | Neff Ovens
I have a Bosch double oven. The upper oven works fine. The lower oven does not work at all. After turning on the oven, when I turn the thermostat, nothing happens, even the light is not on. Thanks
Hi there
i would first check that your timer is not set to auto if it is switch off cooker at mains wait 5 seconds then switch on and set time, if this is not the problem it sounds like the overheat cut-out located at the back of the oven cavity is at fault.
Ian.
Apr 16, 2011 | Ovens
My cooker keeps switching off during cooking even when the timer is not set, the grill does the same
depending on the make some ovens have a thermister where if the oven gets too hot it will cut out untill it cools back down, possibly the thermister is faulty.
Apr 06, 2010 | Ovens
Keeps going off when above 180 degrees, then back on again after 10-15 minutes ?!
Hi.
Without knowing your exact make and model I can only guess that your console cooling fan (sits at the top back of your oven) has failed. This is used to keep the the clock and controls from overheating. If it failes then a safety switch will activate and turn everything off in your cooker. when it cools down it will remake the contact and then switch everything back on again.
Hope this helps
Aardvark Repairs
Nov 15, 2009 | AEG B1180-4 Electric Single Oven
Problem with electric single oven Tecnik tkc241/2
Hi, switch off the mains for the cooker, wait for about 15 seconds, switch it on (0:00 flashing) then press the 2 buttons on the left at the same time and hold them, and then press the - or + button to set the time.
Cheers
Feb 19, 2009 | Tecnik TKC215/3 Electric Single Oven
DOOR Locked Flashing
check the interlock switch, can be some object has stuck to it...
Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
Open Questions:
Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range Logo
102 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
